[PATCH 2/2] bsps/i386/shared/cache/cache.c: Make compile
Wed Jan 16 21:44:27 UTC 2019
 bsps/i386/shared/cache/cache.c | 29 +++++++++++++++++++++++++++++
 1 file changed, 29 insertions(+)
diff --git a/bsps/i386/shared/cache/cache.c b/bsps/i386/shared/cache/cache.c
index f8358f2..3d53ff0 100644
--- a/bsps/i386/shared/cache/cache.c
+++ b/bsps/i386/shared/cache/cache.c
@@ -55,11 +55,22 @@ static void _CPU_cache_flush_entire_data(void)
   __asm__ volatile ("wbinvd");
 static void _CPU_cache_invalidate_entire_data(void)
   __asm__ volatile ("invd");
+static void _CPU_cache_invalidate_entire_instruction(void)
+  __asm__ volatile ("invd");
+static void _CPU_cache_invalidate_1_instruction_line(const void *i_addr)
+  _CPU_cache_invalidate_entire_instruction();
 static void _CPU_cache_enable_data(void)
   _CPU_enable_cache();
@@ -70,6 +81,24 @@ static void _CPU_cache_disable_data(void)
   _CPU_disable_cache();
+static void _CPU_cache_enable_instruction(void)
+  _CPU_enable_cache();
+static void _CPU_cache_disable_instruction(void)
+  _CPU_disable_cache();
+static void _CPU_cache_freeze_instruction(void)
+static void _CPU_cache_unfreeze_instruction(void)
 #endif
 #include "../../../shared/cache/cacheimpl.h"
1.8.3.1
