[PATCH] RSB: add RISC-V simulator to gdb
Joel Sherrill
joel at rtems.org
Thu Jan 17 00:33:52 UTC 2019
On Wed, Jan 16, 2019 at 6:28 PM Chris Johns <chrisj at rtems.org> wrote:
> On 17/1/19 5:18 am, Jiri Gaisler wrote:
> > This patch adds the RISC-V version of the sis simulator to gdb-8.2. The
> > SPARC build of RSB is also switched to gdb-8.2 to use the new simulator
> > as it provides both SPARC and RISC-V emulation.
> Thank for this. I only have an admin question.
> Should the patch be on a ticket to make sure it is available and tracked
> within
> RTEMS servers?
Not this patch I assume. I think you mean the gdb patch referenced here:
+%patch add gdb https://gaisler.se/gdb/sis-riscv-2.9.diff
We have tried to avoid dependencies on Jiri's personal servers so no
point in adding one now. :)
Filing a ticket just so it can have the gdb patch attached is good. Do we
close it when we are using the patch or when it is upstream?
--joel
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190116/141df749/attachment.html>
