[PATCH] RSB: add RISC-V simulator to gdb
Thu Jan 17 06:36:30 UTC 2019
On 17/01/2019 07:34, Chris Johns wrote:
> On 17/1/19 11:33 am, Joel Sherrill wrote:
>> On Wed, Jan 16, 2019 at 6:28 PM Chris Johns <chrisj at rtems.org
>> <mailto:chrisj at rtems.org>> wrote:
>>      On 17/1/19 5:18 am, Jiri Gaisler wrote:
>>      > This patch adds the RISC-V version of the sis simulator to gdb-8.2. The
>>      > SPARC build of RSB is also switched to gdb-8.2 to use the new simulator
>>      > as it provides both SPARC and RISC-V emulation.
>>      Thank for this. I only have an admin question.
>>      Should the patch be on a ticket to make sure it is available and tracked within
>>      RTEMS servers?
>> Not this patch I assume. I think you mean the gdb patch referenced here:
>> +%patch add gdb https://gaisler.se/gdb/sis-riscv-2.9.diff
> Yes I was, sorry for not being clearer about this.
>> We have tried to avoid dependencies on Jiri's personal servers so no
>> point in adding one now. :)
> Yes.
>> Filing a ticket just so it can have the gdb patch attached is good. Do we
>> close it when we are using the patch or when it is upstream?
> That is a good idea and use of the ticket. I would not assign a milestone so it
> floats on a release.
The SPARC SIS patches are here:
http://devel.rtems.org/ticket/3460
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
