[PATCH 2/2] Change default prefix
Fri Jan 18 09:09:38 UTC 2019
On 17/01/2019 11:34, Sebastian Huber wrote:
> Use OS prefix + "rtems" + $rtems_version as the default prefix to
> automatically separate different RTEMS versions.
> Close #3675.
>   source-builder/sb/options.py | 6 ++++++
>   1 file changed, 6 insertions(+)
> diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py
> index c5fcabe..e08b088 100644
> --- a/source-builder/sb/options.py
> +++ b/source-builder/sb/options.py
> @@ -307,6 +307,12 @@ class command_line:
>           # Must have a host
>           if self.defaults['_build'] == self.defaults['nil']:
>               raise error.general('--build not set')
> +        # Default prefix
> +        prefix = self.parse_args('--prefix')
> +        if prefix is None:
> +            value = path.join(self.defaults['_prefix'], 'rtems', str(version.version()))
> +            self.opts['prefix'] = value
> +            self.defaults['_prefix'] = value
>           # Manage the regression option
>           if self.opts['regression'] != '0':
>               self.opts['no-install'] = '1'
I would like to back port this change to all open RSB branches. What
didn't work is this:
../source-builder/sb-set-builder --rtems-version=6 6/rtems-sparc
error: unknown option: --rtems-version
Build FAILED
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
