[PATCH v3 7/8] grlib: make memory coherency cpu-independent
Jiri Gaisler jiri at gaisler.se
Mon Jan 21 10:16:27 UTC 2019
On 1/21/19 7:26 AM, Sebastian Huber wrote:
> On 18/01/2019 23:34, Jiri Gaisler wrote:
>>   -extern int   CPU_SPARC_HAS_SNOOPING;
>> +extern int   GRLIB_DMA_IS_CACHE_COHERENT;
> I would leave the SPARC BSPs as is. Maybe someone uses this CPU_SPARC_HAS_SNOOPING in external drivers or whatever. I would use the GRLIB_DMA_IS_CACHE_COHERENT only in the grlib and place something like this in grlib_impl.h:
> #include <bsp.h>
> #ifdef __sparc__
> #define GRLIB_DMA_IS_CACHE_COHERENT CPU_SPARC_HAS_SNOOPING
> #else
> #define GRLIB_DMA_IS_CACHE_COHERENT 1
> #endif
OK, I will fix this. I will skip '#include <bsp.h>' as it creates problems in grlib/mem/mctrl.c (redefinition of struct mctrl_regs). However, since CPU_SPARC_HAS_SNOOPING is defined in bsp.h, any external driver that uses CPU_SPARC_HAS_SNOOPING already include bsp.h ...
