[PATCH v3 7/8] grlib: make memory coherency cpu-independent
Mon Jan 21 10:35:49 UTC 2019
On 21/01/2019 11:16, Jiri Gaisler wrote:
> On 1/21/19 7:26 AM, Sebastian Huber wrote:
>> On 18/01/2019 23:34, Jiri Gaisler wrote:
>>>    -extern int   CPU_SPARC_HAS_SNOOPING;
>>> +extern int   GRLIB_DMA_IS_CACHE_COHERENT;
>> I would leave the SPARC BSPs as is. Maybe someone uses this CPU_SPARC_HAS_SNOOPING in external drivers or whatever. I would use the GRLIB_DMA_IS_CACHE_COHERENT only in the grlib and place something like this in grlib_impl.h:
>> #include <bsp.h>
>> #ifdef __sparc__
>> #define GRLIB_DMA_IS_CACHE_COHERENT CPU_SPARC_HAS_SNOOPING
>> #else
>> #define GRLIB_DMA_IS_CACHE_COHERENT 1
>> #endif
> OK, I will fix this. I will skip '#include <bsp.h>' as it creates problems in grlib/mem/mctrl.c (redefinition of struct mctrl_regs). However, since CPU_SPARC_HAS_SNOOPING is defined in bsp.h, any external driver that uses CPU_SPARC_HAS_SNOOPING already include bsp.h ...
This double definition of struct mctrl_regs should be fixed at some time.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
