[PATCH v4 6/8] grlib: use cpu-independent routines for uncached access
Jiri Gaisler jiri at gaisler.se
Mon Jan 21 15:49:47 UTC 2019
 bsps/include/grlib/grlib_impl.h               | 52 +++++++++++++++++++
 bsps/shared/grlib/1553/b1553brm.c             | 10 +---
 bsps/shared/grlib/1553/b1553rt.c              | 11 +---
 bsps/shared/grlib/can/grcan.c                 | 27 ++--------
 bsps/shared/grlib/pci/grpci2dma.c             |  2 +-
 bsps/shared/grlib/spw/grspw.c                 | 33 +++---------
 bsps/shared/grlib/spw/grspw_pkt.c             |  2 +-
 cpukit/score/cpu/riscv/headers.am             |  2 +
 .../score/cpu/riscv/include/libcpu/access.h   | 50 ++++++++++++++++++
 .../cpu/riscv/include/libcpu/byteorder.h      | 31 +++++++++++
 10 files changed, 149 insertions(+), 71 deletions(-)
 create mode 100644 cpukit/score/cpu/riscv/include/libcpu/access.h
 create mode 100644 cpukit/score/cpu/riscv/include/libcpu/byteorder.h
diff --git a/bsps/include/grlib/grlib_impl.h b/bsps/include/grlib/grlib_impl.h
index 9a7fa15a5e..f1260671e0 100644
--- a/bsps/include/grlib/grlib_impl.h
+++ b/bsps/include/grlib/grlib_impl.h
@@ -90,6 +90,58 @@ RTEMS_INLINE_ROUTINE void *grlib_calloc(size_t nelem, size_t elsize)
 #endif
+#ifdef __sparc
+RTEMS_INLINE_ROUTINE unsigned char grlib_read_uncached8(unsigned int address)
+       unsigned char tmp;
+       __asm__ (" lduba [%1]1, %0 "
+           : "=r"(tmp)
+           : "r"(address)
+       return tmp;
+RTEMS_INLINE_ROUTINE unsigned short grlib_read_uncached16(unsigned int addr) {
+       unsigned short tmp;
+       __asm__ (" lduha [%1]1, %0 "
+         : "=r"(tmp)
+         : "r"(addr)
+       return tmp;
+RTEMS_INLINE_ROUTINE unsigned int grlib_read_uncached32(unsigned int address)
+	unsigned int tmp;
+	__asm__ (" lda [%1]1, %0 "
+	        : "=r"(tmp)
+	        : "r"(address)
+	return tmp;
+#else
+static unsigned char __inline__ grlib_read_uncached8(unsigned int address)
+	unsigned char tmp = (*(volatile unsigned char *)(address));
+	return tmp;
+static __inline__ unsigned short grlib_read_uncached16(unsigned int address) {
+	unsigned short tmp = (*(volatile unsigned short *)(address));
+	return tmp;
+	unsigned int tmp = (*(volatile unsigned int *)(address));
+	return tmp;
+#endif
 extern struct ambapp_bus ambapp_plb;
 #ifdef __cplusplus
diff --git a/bsps/shared/grlib/1553/b1553brm.c b/bsps/shared/grlib/1553/b1553brm.c
index 5575abb525..57ef70126b 100644
--- a/bsps/shared/grlib/1553/b1553brm.c
+++ b/bsps/shared/grlib/1553/b1553brm.c
@@ -59,15 +59,7 @@
 #endif
 #define READ_REG(address) (*(volatile unsigned int *)address)
-#define READ_DMA(address) _BRM_REG_READ16((unsigned int)address)
-static __inline__ unsigned short _BRM_REG_READ16(unsigned int addr) {
-	unsigned short tmp;
-	__asm__ (" lduha [%1]1, %0 "
-	  : "=r"(tmp)
-	  : "r"(addr)
-	return tmp;
+#define READ_DMA(address) grlib_read_uncached16((unsigned int)address)
 static rtems_device_driver brm_initialize(rtems_device_major_number major, rtems_device_minor_number minor, void *arg);
 static rtems_device_driver brm_open(rtems_device_major_number major, rtems_device_minor_number minor, void *arg);
diff --git a/bsps/shared/grlib/1553/b1553rt.c b/bsps/shared/grlib/1553/b1553rt.c
index 35afd901c8..d7257e461f 100644
--- a/bsps/shared/grlib/1553/b1553rt.c
+++ b/bsps/shared/grlib/1553/b1553rt.c
@@ -52,16 +52,7 @@
 #define FUNCDBG(x...)
 #endif
-#define READ_DMA(address) _READ16((unsigned int)address)
-static __inline__ unsigned short _READ16(unsigned int addr) {
-    asm(" lduha [%1]1, %0 "
-        : "=r"(tmp)
-        : "r"(addr)
-    return tmp;
 static rtems_device_driver rt_initialize(rtems_device_major_number major, rtems_device_minor_number minor, void *arg);
 static rtems_device_driver rt_open(rtems_device_major_number major, rtems_device_minor_number minor, void *arg);
diff --git a/bsps/shared/grlib/can/grcan.c b/bsps/shared/grlib/can/grcan.c
index 55154d823a..d69d99d85a 100644
--- a/bsps/shared/grlib/can/grcan.c
+++ b/bsps/shared/grlib/can/grcan.c
@@ -165,40 +165,19 @@ static void grcan_hw_sync(
 static void grcan_interrupt(void *arg);
 #ifdef GRCAN_REG_BYPASS_CACHE
-#define READ_REG(address) _grcan_read_nocache((unsigned int)(address))
+#define READ_REG(address) grlib_read_uncached32((unsigned int)(address))
 #else
 #define READ_REG(address) (*(volatile unsigned int *)(address))
 #endif
 #ifdef GRCAN_DMA_BYPASS_CACHE
-#define READ_DMA_WORD(address) _grcan_read_nocache((unsigned int)(address))
-#define READ_DMA_BYTE(address) _grcan_read_nocache_byte((unsigned int)(address))
-static unsigned char __inline__ _grcan_read_nocache_byte(unsigned int address)
-	unsigned char tmp;
-	__asm__ (" lduba [%1]1, %0 "
-	    : "=r"(tmp)
-	    : "r"(address)
-	return tmp;
+#define READ_DMA_WORD(address) grlib_read_uncached32((unsigned int)(address))
+#define READ_DMA_BYTE(address) grlib_read_uncached8((unsigned int)(address))
 #else
 #define READ_DMA_WORD(address) (*(volatile unsigned int *)(address))
 #define READ_DMA_BYTE(address) (*(volatile unsigned char *)(address))
 #endif
-#if defined(GRCAN_REG_BYPASS_CACHE) || defined(GRCAN_DMA_BYPASS_CACHE)
-static unsigned int __inline__ _grcan_read_nocache(unsigned int address)
-	unsigned int tmp;
-	__asm__ (" lda [%1]1, %0 "
-	        : "=r"(tmp)
-	        : "r"(address)
-	return tmp;
-#endif
 #define NELEM(a) ((int) (sizeof (a) / sizeof (a[0])))
 static int grcan_count = 0;
diff --git a/bsps/shared/grlib/pci/grpci2dma.c b/bsps/shared/grlib/pci/grpci2dma.c
index 7e39ca691d..cb41d48966 100644
--- a/bsps/shared/grlib/pci/grpci2dma.c
+++ b/bsps/shared/grlib/pci/grpci2dma.c
@@ -98,7 +98,7 @@
 /* Memory and HW Registers Access routines. All 32-bit access routines */
 #define BD_WRITE(addr, val) (*(volatile unsigned int *)(addr) = (unsigned int)(val))
 /*#define BD_READ(addr) (*(volatile unsigned int *)(addr))*/
-#define BD_READ(addr) leon_r32_no_cache((unsigned long)(addr))
+#define BD_READ(addr) grlib_read_uncached32((unsigned long)(addr))
 #define REG_WRITE(addr, val) (*(volatile unsigned int *)(addr) = (unsigned int)(val))
 #define REG_READ(addr) (*(volatile unsigned int *)(addr))
diff --git a/bsps/shared/grlib/spw/grspw.c b/bsps/shared/grlib/spw/grspw.c
index ca0f63edd8..fbaadd1e13 100644
--- a/bsps/shared/grlib/spw/grspw.c
+++ b/bsps/shared/grlib/spw/grspw.c
@@ -25,6 +25,10 @@
 #include <grlib/grlib_impl.h>
+#ifndef CPU_SPARC_HAS_SNOOPING
+#define CPU_SPARC_HAS_SNOOPING 1
+#endif
 #define DBGSPW_IOCALLS 1
 #define DBGSPW_TX 2
 #define DBGSPW_RX 4
@@ -152,32 +156,9 @@ void (*grspw_timecode_callback)
 #define _MEM_READ8(address) (*(volatile unsigned char *)(address))
 #define _MEM_READ32(address) (*(volatile unsigned int *)(address))
 #else
-static inline unsigned int _SPW_READ(volatile void *addr) {
-        unsigned int tmp;
-            : "=r"(tmp)
-            : "r"(addr)
-        return tmp;
-static inline unsigned int _MEM_READ8(volatile void *addr) {
-        unsigned int tmp;
-            : "=r"(tmp)
-            : "r"(addr)
-        return tmp;
-static inline unsigned int _MEM_READ32(volatile void *addr) {
-        unsigned int tmp;
-            : "=r"(tmp)
-            : "r"(addr)
-        return tmp;
+#define _SPW_READ(address) grlib_read_uncached32((unsigned int) address)
+#define _MEM_READ8(address) grlib_read_uncached8((unsigned int) address)
+#define _MEM_READ32(address) grlib_read_uncached32((unsigned int) address)
 #endif
 #define MEM_READ8(addr) _MEM_READ8((volatile void *)(addr))
diff --git a/bsps/shared/grlib/spw/grspw_pkt.c b/bsps/shared/grlib/spw/grspw_pkt.c
index 208f5a14f7..56b39d78db 100644
--- a/bsps/shared/grlib/spw/grspw_pkt.c
+++ b/bsps/shared/grlib/spw/grspw_pkt.c
@@ -315,7 +315,7 @@ struct grspw_txbd {
diff --git a/cpukit/score/cpu/riscv/headers.am b/cpukit/score/cpu/riscv/headers.am
index 415075ce46..abb8a42f78 100644
--- a/cpukit/score/cpu/riscv/headers.am
+++ b/cpukit/score/cpu/riscv/headers.am
@@ -1,4 +1,6 @@
 ## This file was generated by "./boostrap -H".
+include_libcpu_HEADERS += score/cpu/riscv/include/libcpu/access.h
+include_libcpu_HEADERS += score/cpu/riscv/include/libcpu/byteorder.h
 include_rtems_HEADERS += score/cpu/riscv/include/rtems/asm.h
 include_rtems_score_HEADERS += score/cpu/riscv/include/rtems/score/cpu.h
 include_rtems_score_HEADERS += score/cpu/riscv/include/rtems/score/cpu_asm.h
diff --git a/cpukit/score/cpu/riscv/include/libcpu/access.h b/cpukit/score/cpu/riscv/include/libcpu/access.h
new file mode 100644
index 0000000000..cdf6b77122
--- /dev/null
+++ b/cpukit/score/cpu/riscv/include/libcpu/access.h
@@ -0,0 +1,50 @@
+ *  access.h  - access routines for SPARC. SPARC is big endian only.
+ *  COPYRIGHT (c) 2011
+ *  Aeroflex Gaisler.
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#ifndef _LIBCPU_ACCESS_H
+#define _LIBCPU_ACCESS_H
+#include <rtems/system.h>
+#include <rtems/score/cpu.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* "Raw" access */
+extern uint8_t _ld8(uint8_t *addr);
+extern void _st8(uint8_t *addr, uint8_t val);
+extern uint16_t _ld16(uint16_t *addr);
+extern void _st16(uint16_t *addr, uint16_t val);
+extern uint32_t _ld32(uint32_t *addr);
+extern void _st32(uint32_t *addr, uint32_t val);
+extern uint64_t _ld64(uint64_t *addr);
+extern void _st64(uint64_t *addr, uint64_t val);
+/* Aliases for Big Endian */
+extern uint16_t _ld_be16(uint16_t *addr);
+extern void _st_be16(uint16_t *addr, uint16_t val);
+extern uint32_t _ld_be32(uint32_t *addr);
+extern void _st_be32(uint32_t *addr, uint32_t val);
+extern uint64_t _ld_be64(uint64_t *addr);
+extern void _st_be64(uint64_t *addr, uint64_t val);
+/* Little endian */
+extern uint16_t _ld_le16(uint16_t *addr);
+extern void _st_le16(uint16_t *addr, uint16_t val);
+extern uint32_t _ld_le32(uint32_t *addr);
+extern void _st_le32(uint32_t *addr, uint32_t val);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/score/cpu/riscv/include/libcpu/byteorder.h b/cpukit/score/cpu/riscv/include/libcpu/byteorder.h
index 0000000000..939e51fe84
--- /dev/null
+++ b/cpukit/score/cpu/riscv/include/libcpu/byteorder.h
@@ -0,0 +1,31 @@
+#ifndef _LIBCPU_BYTEORDER_H
+#define _LIBCPU_BYTEORDER_H
+static inline void st_le32(volatile uint32_t   *addr, uint32_t   value)
+  *(addr)=value ;
+static inline uint32_t   ld_le32(volatile uint32_t   *addr)
+  return(*addr);
+static inline void st_le16(volatile uint16_t   *addr, uint16_t   value)
+  *(addr)=value ;
+static inline uint16_t   ld_le16(volatile uint16_t   *addr)
+  return(*addr);
+#endif
2.17.1
