[PATCH] sb: Fix the RTEMS options after strict option checking was added.
Chris Johns
chrisj at rtems.org
Tue Jan 22 02:33:57 UTC 2019
source-builder/sb/options.py | 15 +++++++++------
1 file changed, 9 insertions(+), 6 deletions(-)
diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py
index c5fcabe..eb0c2d5 100644
--- a/source-builder/sb/options.py
+++ b/source-builder/sb/options.py
@@ -53,7 +53,7 @@ class command_line:
def __init__(self, argv, optargs, _defaults, command_path):
self._long_opts = {
- # key macro handler param defs init
+ # key macro handler param defs init
'--prefix' : ('_prefix', self._lo_path, True, None, False),
'--topdir' : ('_topdir', self._lo_path, True, None, False),
'--configdir' : ('_configdir', self._lo_path, True, None, False),
@@ -83,6 +83,9 @@ class command_line:
'--host' : ('_host', self._lo_triplets, True, None, False),
'--build' : ('_build', self._lo_triplets, True, None, False),
'--target' : ('_target', self._lo_triplets, True, None, False),
+ '--rtems-tools' : ('_rtems_tools', self._lo_string, True, None, False),
+ '--rtems-bsp' : ('_rtems_bsp', self._lo_string, True, None, False),
+ '--rtems-version' : ('_rtems_version', self._lo_string, True, None, False),
'--help' : (None, self._lo_help, False, None, False)
@@ -575,6 +578,11 @@ class command_line:
if self.get_arg('--with-tools') is not None:
raise error.general('--rtems-tools and --with-tools cannot be used together')
self.args.append('--with-tools=%s' % (rtems_tools[1]))
+ rtems_version = self.parse_args('--rtems-version')
+ if rtems_version is None:
+ rtems_version = version.version()
+ else:
+ rtems_version = rtems_version[1]
rtems_arch_bsp = self.parse_args('--rtems-bsp')
if rtems_arch_bsp is not None:
if self.get_arg('--target') is not None:
@@ -582,11 +590,6 @@ class command_line:
ab = rtems_arch_bsp[1].split('/')
if len(ab) != 2:
raise error.general('invalid --rtems-bsp option')
- rtems_version = self.parse_args('--rtems-version')
- if rtems_version is None:
- rtems_version = version.version()
- else:
- rtems_version = rtems_version[1]
self.args.append('--target=%s-rtems%s' % (ab[0], rtems_version))
self.args.append('--with-rtems-bsp=%s' % (ab[1]))
2.19.1
