[PATCH] sb: Fix the RTEMS options after strict option checking was added.
Tue Jan 22 05:28:12 UTC 2019
On 22/01/2019 03:33, Chris Johns wrote:
>   source-builder/sb/options.py | 15 +++++++++------
>   1 file changed, 9 insertions(+), 6 deletions(-)
> diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py
> index c5fcabe..eb0c2d5 100644
> --- a/source-builder/sb/options.py
> +++ b/source-builder/sb/options.py
> @@ -53,7 +53,7 @@ class command_line:
>       def __init__(self, argv, optargs, _defaults, command_path):
>           self._long_opts = {
> -            # key                 macro                handler            param  defs   init
> +            # key                       macro                handler            param  defs   init
>               '--prefix'               : ('_prefix',           self._lo_path,     True,  None,  False),
>               '--topdir'               : ('_topdir',           self._lo_path,     True,  None,  False),
>               '--configdir'            : ('_configdir',        self._lo_path,     True,  None,  False),
> @@ -83,6 +83,9 @@ class command_line:
>               '--host'                 : ('_host',             self._lo_triplets, True,  None,  False),
>               '--build'                : ('_build',            self._lo_triplets, True,  None,  False),
>               '--target'               : ('_target',           self._lo_triplets, True,  None,  False),
> +            '--rtems-tools'          : ('_rtems_tools',      self._lo_string,   True,  None,  False),
> +            '--rtems-bsp'            : ('_rtems_bsp',        self._lo_string,   True,  None,  False),
> +            '--rtems-version'        : ('_rtems_version',    self._lo_string,   True,  None,  False),
>               '--help'                 : (None,                self._lo_help,     False, None,  False)
> @@ -575,6 +578,11 @@ class command_line:
>               if self.get_arg('--with-tools') is not None:
>                   raise error.general('--rtems-tools and --with-tools cannot be used together')
>               self.args.append('--with-tools=%s' % (rtems_tools[1]))
> +        rtems_version = self.parse_args('--rtems-version')
> +        if rtems_version is None:
> +            rtems_version = version.version()
> +        else:
> +            rtems_version = rtems_version[1]
>           rtems_arch_bsp = self.parse_args('--rtems-bsp')
>           if rtems_arch_bsp is not None:
>               if self.get_arg('--target') is not None:
> @@ -582,11 +590,6 @@ class command_line:
>               ab = rtems_arch_bsp[1].split('/')
>               if len(ab) != 2:
>                   raise error.general('invalid --rtems-bsp option')
> -            rtems_version = self.parse_args('--rtems-version')
> -            if rtems_version is None:
> -                rtems_version = version.version()
> -            else:
> -                rtems_version = rtems_version[1]
>               self.args.append('--target=%s-rtems%s' % (ab[0], rtems_version))
>               self.args.append('--with-rtems-bsp=%s' % (ab[1]))
Thanks, this makes the options available. I would like to use it also to
change the default prefix, e.g.
../source-builder/sb-set-builder --rtems-version=6 6/rtems-sparc
-> "/opt/rtems/6"
I need to save the RTEMS version somewhere, the rtems_version is not a
global variable.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
