[PATCH v2] sb: Fix the RTEMS options after strict option checking was added.
Chris Johns
chrisj at rtems.org
Tue Jan 22 06:18:21 UTC 2019
rtems/config/rtems-version.bset | 4 +++-
source-builder/sb/options.py | 16 ++++++++++------
2 files changed, 13 insertions(+), 7 deletions(-)
diff --git a/rtems/config/rtems-version.bset b/rtems/config/rtems-version.bset
index b2db1ba..977f268 100644
--- a/rtems/config/rtems-version.bset
+++ b/rtems/config/rtems-version.bset
@@ -2,4 +2,6 @@
# Current version is RTEMS 5
-%define rtems_version 5
+%if %{!defined rtems_version}
+ %error RTEMS version is not defined
+%endif
diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py
index c5fcabe..f6963ac 100644
--- a/source-builder/sb/options.py
+++ b/source-builder/sb/options.py
@@ -53,7 +53,7 @@ class command_line:
def __init__(self, argv, optargs, _defaults, command_path):
self._long_opts = {
- # key macro handler param defs init
+ # key macro handler param defs init
'--prefix' : ('_prefix', self._lo_path, True, None, False),
'--topdir' : ('_topdir', self._lo_path, True, None, False),
'--configdir' : ('_configdir', self._lo_path, True, None, False),
@@ -83,6 +83,9 @@ class command_line:
'--host' : ('_host', self._lo_triplets, True, None, False),
'--build' : ('_build', self._lo_triplets, True, None, False),
'--target' : ('_target', self._lo_triplets, True, None, False),
+ '--rtems-tools' : ('_rtems_tools', self._lo_string, True, None, False),
+ '--rtems-bsp' : ('_rtems_bsp', self._lo_string, True, None, False),
+ '--rtems-version' : ('_rtems_version', self._lo_string, True, None, False),
'--help' : (None, self._lo_help, False, None, False)
@@ -575,6 +578,12 @@ class command_line:
if self.get_arg('--with-tools') is not None:
raise error.general('--rtems-tools and --with-tools cannot be used together')
self.args.append('--with-tools=%s' % (rtems_tools[1]))
+ rtems_version = self.parse_args('--rtems-version')
+ if rtems_version is None:
+ rtems_version = version.version()
+ else:
+ rtems_version = rtems_version[1]
+ self.defaults['rtems_version'] = rtems_version
rtems_arch_bsp = self.parse_args('--rtems-bsp')
if rtems_arch_bsp is not None:
if self.get_arg('--target') is not None:
@@ -582,11 +591,6 @@ class command_line:
ab = rtems_arch_bsp[1].split('/')
if len(ab) != 2:
raise error.general('invalid --rtems-bsp option')
- rtems_version = self.parse_args('--rtems-version')
- if rtems_version is None:
- rtems_version = version.version()
- else:
- rtems_version = rtems_version[1]
self.args.append('--target=%s-rtems%s' % (ab[0], rtems_version))
self.args.append('--with-rtems-bsp=%s' % (ab[1]))
2.19.1
