[PATCH v4 0/8] Adding griscv bsp
Tue Jan 22 12:00:56 UTC 2019
On 21/01/2019 16:49, Jiri Gaisler wrote:
> Fourth take on adding a bsp for a RISC-V GRLIB cpu, taking into account
> previous comments.
> Jiri Gaisler (6):
>    grlib: Fix inludes
>    grlib: make apbuart driver independent of bsp
>    grlib: use rtems_interrupt_handler_install() for all interrupt
>      handlers
>    grlib: use cpu-independent routines for uncached access
>    grlib: make memory coherency cpu-independent
>    riscv: add griscv bsp
> Sebastian Huber (2):
>    grlib: Move header files
>    grlib: Move source files
I added a ticket for this BSP:
http://devel.rtems.org/ticket/3678
I checked in a slightly modified patch set. For example to fix build
errors with the leon2 BSP. I added also a documentation stub:
https://docs.rtems.org/branches/master/user/bsps/bsps-riscv.html#griscv
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
