Building Ada for RTEMS
Tue Jan 22 22:07:41 UTC 2019
On 23/1/19 9:04 am, Joel Sherrill wrote:
> Notice that the build succeeds when using a native version that matches the
> version being built cross. This is in keeping with long-standing advice.
Should the RSB be taught to check for gcc and the native version if an Ada build
is requested?
Can we assume an Ada build fails with a clang native tool set?
Should we provide a bare build set for the needed native gcc?
