Building Ada for RTEMS
Wed Jan 23 06:22:49 UTC 2019
Hello Joel,
On 22/01/2019 23:04, Joel Sherrill wrote:
> Hi
> I put this on hold for the Christmas holidays and wanted to post what
> worked and didn't for me. This is on Centos 7 building C, C++ and Ada
> to target sparc-rtems5 using the RSB master.
> I tried various gcc versions with Ada support. I ensured which gcc I
> was using by putting it at the front of my PATH and doing "gcc
> --version" before I started the RSB build.
> + RSB build fails with base gcc from CentOS. It is gcc 4.8.5
> + RSB build fails with gcc from git master.
> + RSB build fails with gcc 8.2.0
> + RSB build succeeds with gcc 7.4.0
> Notice that the build succeeds when using a native version that
> matches the version being built cross. This is in keeping with
> long-standing advice.
the current situation for GCC 9 is less good. I was not able to build it
on Debian:
https://gcc.gnu.org/ml/gcc/2019-01/msg00141.html
On openSUSE it worked.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
