Zynq RTEMS Networking Configuration Setup (no #defines in BSP)
Thu Jan 24 07:04:24 UTC 2019
On 24/01/2019 03:16, Misra, Avinash wrote:
> My question is, is there a way through libbsd that I can set up my UDP
> and TCP/IP socket sizes or are the network driver and attach function
> defined for the Zynq somewhere that I can use to configure the network
> on my Zynq platform using the instructions in the documentation?
The Zynq network support for RTEMS is provided by the libbsd. You can
try it out on Qemu. For example with the tests included in libbsd.
https://github.com/RTEMS/rtems-libbsd/blob/master/README.md
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
