[PATCH 02/10] user: Fix references to prefixes section
Thu Jan 24 08:55:11 UTC 2019
 user/hosts/macos.rst                     | 2 +-
 user/hosts/posix.rst                     | 2 +-
 user/installation/project-sandboxing.rst | 3 ---
 user/installation/releases.rst           | 4 ++--
 user/start/prefixes.rst                  | 5 +++--
 5 files changed, 7 insertions(+), 9 deletions(-)
diff --git a/user/hosts/macos.rst b/user/hosts/macos.rst
index ecc2617..c68e627 100644
--- a/user/hosts/macos.rst
+++ b/user/hosts/macos.rst
@@ -17,7 +17,7 @@ The normal prefix when working on OS X as a user is under your home directory.
 Prefixes of :file:`$HOME/development/rtems` or :file:`$HOME/rtems` are
 suitable.
-:ref:`prefixes` details using Prefixes to manage the installation.
+:ref:`QuickStartPrefixes` details using Prefixes to manage the installation.
 MacOS
 .. _Mavericks:
diff --git a/user/hosts/posix.rst b/user/hosts/posix.rst
index 38f4b30..365194e 100644
--- a/user/hosts/posix.rst
+++ b/user/hosts/posix.rst
@@ -22,7 +22,7 @@ directory. You could use a prefix of :file:`$HOME/development/rtems` or
 :file:`$HOME/rtems`. Note, the ``$HOME`` environment variable can be
 substituted with ``~``.
 RTEMS Tools and packages do not require ``root`` access
 to be built and we encourage you to not build the tools as ``root``. If you
diff --git a/user/installation/project-sandboxing.rst b/user/installation/project-sandboxing.rst
index 2c5e508..6c90926 100644
--- a/user/installation/project-sandboxing.rst
+++ b/user/installation/project-sandboxing.rst
@@ -2,9 +2,6 @@
 .. Copyright (C) 2016 Chris Johns <chrisj at rtems.org>
-.. index:: Prefixes
-.. _prefixes:
 .. _project-sandboxing:
 Project Sandboxing
diff --git a/user/installation/releases.rst b/user/installation/releases.rst
index 17d4e04..10ef30e 100644
--- a/user/installation/releases.rst
+++ b/user/installation/releases.rst
@@ -27,8 +27,8 @@ use a home directory, If building on Windows use :file:`/c/opt/rtems` to keep
 the top level paths as short as possible. :ref:`windows-path-length` provides
 more detail about path lengths on Windows.
-The location used to install the tools and kernel is called the
-`prefix`. :ref:`prefixes` explains prefixes and how to use them. It is best to
+The location used to install the tools and kernel is called the `prefix`.
+:ref:`QuickStartPrefixes` explains prefixes and how to use them. It is best to
 have a `prefix` for each different version of RTEMS you are using. If you are
 using RTEMS 4.11 in production it is **not** a good idea to install a
 development version of 5 over the top by using the same `prefix` as the 4.11
diff --git a/user/start/prefixes.rst b/user/start/prefixes.rst
index e9dad29..87e76a1 100644
--- a/user/start/prefixes.rst
+++ b/user/start/prefixes.rst
@@ -2,12 +2,13 @@
-.. index:: prefix
-.. _prefixes:
+.. _QuickStartPrefixes:
 Prefixes
+.. index:: prefix
 You will see the term :ref:term:`prefix` referred to thoughout this
 documentation and in a wide number of software packages you can download from
 the internet. A **prefix** is the path on your computer a software package is
2.16.4
