[PATCH] rtems-tools/covoar: -f switch was not used to select coverage format
Jiri Gaisler
jiri at gaisler.se
Thu Jan 24 12:38:34 UTC 2019
Small patch to fix covoar to work with TSIM coverage files. It should be noted that covoar erroneously marks some code as uncovered while it is marked as covered in the coverage file. This seems to be due to incorrect parsing of the symbol table in the exec file. I will file a ticket for this on trac ..
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190124/e2ce1541/attachment.bin>
