[PATCH] rtems-tools/covoar: -f switch was not used to select coverage format
Joel Sherrill
joel at rtems.org
Thu Jan 24 13:19:26 UTC 2019
On Thu, Jan 24, 2019, 6:38 AM Jiri Gaisler <jiri at gaisler.se wrote:
> Small patch to fix covoar to work with TSIM coverage files. It should be
> noted that covoar erroneously marks some code as uncovered while it is
> marked as covered in the coverage file. This seems to be due to incorrect
> parsing of the symbol table in the exec file. I will file a ticket for this
> on trac ..
Is this the entry and exit code of a method or something else? The switch
to dwarf info seems to have caused that and not marking assembly from
inlined methods.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190124/df59e3cf/attachment.html>
