[PATCH] rtems-tools/covoar: Wrong coverage computed
Jiri Gaisler
jiri at gaisler.se
Fri Jan 25 14:43:40 UTC 2019
Sorry for the noise, but I have a better patch that actually solves the root problem. I ran the full testsuite on sis and covoar against libscore.a like this:
$ sparc-rtems5-ar -rcs sparc-rtems5/c/leon3/cpukit/score/libscore.a sparc-rtems5/c/leon3/cpukit/score/src/*.o
$ rtems-test --rtems-bsp=leon3-sis-cov sparc-rtems5/c/leon3/testsuites
$ /opt/rtems/5/share/rtems/tester/bin/covoar -v -f TSIM -S /opt/rtems/5/share/rtems/tester/rtems/testing/coverage/score-symbols.ini -O coverage -E /opt/rtems/5/share/rtems/tester/rtems/testing/coverage/Explanations.txt -p RTEMS-5 sparc-rtems5/c/leon3/testsuites/*/*.exe
summary.txt:
Bytes Analyzed : 39376 Bytes Not Executed : 2864 Percentage Executed : 92.73 Percentage Not Executed : 7.273 Uncovered ranges found : 108 Total branches found : 860 Uncovered branches found : 200 61 branches always taken 139 branches never taken
All symbol sizes and ranges are now correctly reported/calculated in the reports. There are two remaining issues to be solved:
1. File names are printed as 'unknown' in reports (minor problem but useful)
2. We should add RISC-V support to covoar ...
Let me know if you agree to the patch ..
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190125/f2cc26b2/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190125/f2cc26b2/attachment.bin>
