[PATCH v2 00/10] Rework quick start in user manual
Mon Jan 28 12:27:02 UTC 2019
This patch set reworks the quick start chapter in the user manual. You
find a PDF with this patch set here:
https://ftp.rtems.org/pub/rtems/people/sebh/user.pdf
It duplicates some information with the "Installation" chapter.  The
"Installation" chapter should be reworked to contain the details.
The "Build Your Application" is a TODO.
v2:
Fix some issues after first review from Chris.
Sebastian Huber (10):
  user: Rework "Host Computer Setup" section
  user: Fix references to prefixes section
  user: Rework Prefixes section
  user: Add "Obtain the Sources" section
  user: Add "Install the Tool Suite" section
  user: Add "Bootstrap the RTEMS Sources"
  user: Add "Build a Board Support Package (BSP)"
  user: Add "Test a Board Support Package (BSP)"
  user: Add "Build Your Application"
  user: Remove obsolete content in quick start
 user/hardware/architectures.rst          |   3 +
 user/hosts/macos.rst                     |   2 +-
 user/hosts/posix.rst                     |   4 +-
 user/installation/project-sandboxing.rst |   5 +-
 user/installation/releases.rst           |   4 +-
 user/rsb/why-build-from-source.rst       |   2 +
 user/start/app.rst                       |  11 +++
 user/start/bootstrap.rst                 |  55 ++++++++++++
 user/start/bsp-build.rst                 | 146 +++++++++++++++++++++++++++++++
 user/start/bsp-test.rst                  |  66 ++++++++++++++
 user/start/host.rst                      |  22 ++---
 user/start/index.rst                     |  93 ++------------------
 user/start/prefixes.rst                  |  79 +++++++++--------
 user/start/sources.rst                   |  51 +++++++++++
 user/start/tools.rst                     | 126 ++++++++++++++++++++++++++
 user/testing/index.rst                   |   2 +
 user/tools/index.rst                     |   2 +
 17 files changed, 527 insertions(+), 146 deletions(-)
 create mode 100644 user/start/app.rst
 create mode 100644 user/start/bootstrap.rst
 create mode 100644 user/start/bsp-build.rst
 create mode 100644 user/start/bsp-test.rst
 create mode 100644 user/start/sources.rst
 create mode 100644 user/start/tools.rst
2.16.4
