psim failures with -O1
Tue Jan 29 08:48:01 UTC 2019
On 29/01/2019 09:14, Chris Johns wrote:
> Hi,
> I thought it may be a good idea to set the optimization level for the psim BSP
> to `-O1`. The xilinx_zynq_a9_qemu has this and it is useful.
> The change causes the number of test failures to jump from around 20 to over 230.
> Is this expected?
Yes, this is a compiler bug/feature. GCC generates a floating point
instruction in a function which is called in ISR context. This leads to
an exception.
On SPARC using -O0 to run the tests is also problematic due to the much
higher stack usage.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
