[PATCH] rtems-record: New program
    Sebastian Huber
    Tue Jan 29 14:06:49 UTC 2019
 misc/record/record-client.c      | 448 +++++++++++++++++++++++++++++++++++++++
 misc/record/record-main.c        | 309 +++++++++++++++++++++++++++
 misc/record/record-text.c        | 197 +++++++++++++++++
 misc/record/rtems/recordclient.h | 139 ++++++++++++
 misc/record/rtems/recorddata.h   | 317 +++++++++++++++++++++++++++
 misc/wscript                     |  10 +
 6 files changed, 1420 insertions(+)
 create mode 100644 misc/record/record-client.c
 create mode 100644 misc/record/record-main.c
 create mode 100644 misc/record/record-text.c
 create mode 100644 misc/record/rtems/recordclient.h
 create mode 100644 misc/record/rtems/recorddata.h
diff --git a/misc/record/record-client.c b/misc/record/record-client.c
new file mode 100644
index 0000000..585aa38
--- /dev/null
+++ b/misc/record/record-client.c
@@ -0,0 +1,448 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2018, 2019 embedded brains GmbH
+ * are met:
+ * This file must be compatible to general purpose POSIX system, e.g. Linux,
+ * FreeBSD.  It may be used for utility programs.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/recordclient.h>
+#include <string.h>
+static void set_to_bt_scaler(
+  rtems_record_client_context *ctx,
+  uint32_t                     frequency
+  uint64_t bin_per_s;
+  bin_per_s = UINT64_C( 1 ) << 32;
+  ctx->to_bt_scaler = ( ( bin_per_s << 31 ) + frequency - 1 ) / frequency;
+static rtems_record_client_status call_handler(
+  const rtems_record_client_context *ctx,
+  uint64_t                           bt,
+  rtems_record_event                 event,
+  uint64_t                           data
+  uint32_t seconds;
+  uint32_t nanosec;
+  seconds = (uint32_t) ( bt >> 32 );
+  nanosec = (uint32_t) ( ( UINT64_C( 1000000000 ) * (uint32_t) bt ) >> 32 );
+  return ( *ctx->handler )(
+    seconds,
+    nanosec,
+    ctx->cpu,
+    event,
+    data,
+    ctx->handler_arg
+static void check_overflow(
+  const rtems_record_client_per_cpu *per_cpu,
+  uint32_t                           new_head
+  uint32_t last_tail;
+  uint32_t last_head;
+  uint32_t capacity;
+  uint32_t new_content;
+  uint64_t bt;
+  last_tail = per_cpu->tail[ per_cpu->index ];
+  last_head = per_cpu->head[ per_cpu->index ];
+  if ( last_tail == last_head ) {
+    return;
+  capacity = ( last_tail - last_head - 1 ) & ( ctx->count - 1 );
+  new_content = new_head - last_head;
+  if ( new_content <= capacity ) {
+    return;
+  bt = ( per_cpu->uptime.time_accumulated * ctx->to_bt_scaler ) >> 31;
+  bt += per_cpu->uptime.bt;
+  call_handler(
+    ctx,
+    bt,
+    RTEMS_RECORD_OVERFLOW,
+    new_content - capacity
+static rtems_record_client_status visit( rtems_record_client_context *ctx )
+  rtems_record_client_per_cpu *per_cpu;
+  uint32_t                     time;
+  rtems_record_event           event;
+  uint64_t                     data;
+  uint64_t                     bt;
+  per_cpu = &ctx->per_cpu[ ctx->cpu ];
+  time = RTEMS_RECORD_GET_TIME( ctx->event );
+  event = RTEMS_RECORD_GET_EVENT( ctx->event );
+  data = ctx->data;
+  switch ( event ) {
+    case RTEMS_RECORD_PROCESSOR:
+      if ( data >= RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT ) {
+        return RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_CPU;
+      ctx->cpu = (uint32_t) data;
+      break;
+    case RTEMS_RECORD_UPTIME_LOW:
+      per_cpu->uptime.bt = (uint32_t) data;
+      per_cpu->uptime.time_at_bt = time;
+      per_cpu->uptime.time_last = time;
+      per_cpu->uptime.time_accumulated = 0;
+      time = 0;
+      break;
+    case RTEMS_RECORD_UPTIME_HIGH:
+      per_cpu->uptime.bt += (int64_t) data << 32;
+      time = 0;
+      break;
+    case RTEMS_RECORD_TAIL:
+      per_cpu->tail[ per_cpu->index ] = (uint32_t) data;
+      break;
+    case RTEMS_RECORD_HEAD:
+      per_cpu->head[ per_cpu->index ]= (uint32_t) data;
+      per_cpu->index ^= 1;
+      check_overflow( ctx, per_cpu, (uint32_t) data );
+      break;
+    case RTEMS_RECORD_COUNT:
+      ctx->count = (uint32_t) data;
+      break;
+    case RTEMS_RECORD_FREQUENCY:
+      set_to_bt_scaler( ctx, (uint32_t) data );
+      break;
+    case RTEMS_RECORD_VERSION:
+      if ( data != RTEMS_RECORD_THE_VERSION ) {
+        return RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_VERSION;
+      break;
+    default:
+      break;
+  if ( time != 0 ) {
+    uint32_t delta;
+    delta = ( time - per_cpu->uptime.time_last )
+      & ( ( UINT32_C( 1 ) << RTEMS_RECORD_TIME_BITS ) - 1 );
+    per_cpu->uptime.time_accumulated += delta;
+  } else {
+    bt = 0;
+  return call_handler( ctx, bt, event, data );
+static rtems_record_client_status consume_32(
+  const void                  *buf,
+  size_t                       n
+  while ( n > 0 ) {
+    size_t m;
+    char *pos;
+    m = ctx->todo < n ? ctx->todo : n;
+    pos = ctx->pos;
+    pos = memcpy( pos, buf, m );
+    n -= m;
+    buf = (char *) buf + m;
+    if ( m == ctx->todo ) {
+      rtems_record_client_status status;
+      ctx->todo = sizeof( ctx->item.format_32 );
+      ctx->pos = &ctx->item.format_32;
+      ctx->event = ctx->item.format_32.event;
+      ctx->data = ctx->item.format_32.data;
+      status = visit( ctx );
+      if ( status != RTEMS_RECORD_CLIENT_SUCCESS ) {
+        return status;
+    } else {
+      ctx->todo -= m;
+      ctx->pos = pos + m;
+  return RTEMS_RECORD_CLIENT_SUCCESS;
+static rtems_record_client_status consume_64(
+  const void                  *buf,
+  size_t                       n
+  while ( n > 0 ) {
+    size_t m;
+    char *pos;
+    pos = ctx->pos;
+    n -= m;
+      ctx->todo = sizeof( ctx->item.format_64 );
+      ctx->pos = &ctx->item.format_64;
+      ctx->event = ctx->item.format_64.event;
+      ctx->data = ctx->item.format_64.data;
+        return status;
+    } else {
+      ctx->todo -= m;
+static rtems_record_client_status consume_swap_32(
+  const void                  *buf,
+  size_t                       n
+  while ( n > 0 ) {
+    size_t m;
+    char *pos;
+    pos = ctx->pos;
+    n -= m;
+      ctx->event = __builtin_bswap32( ctx->item.format_32.event );
+      ctx->data = __builtin_bswap32( ctx->item.format_32.data );
+        return status;
+    } else {
+      ctx->todo -= m;
+static rtems_record_client_status consume_swap_64(
+  const void                  *buf,
+  size_t                       n
+  while ( n > 0 ) {
+    size_t m;
+    char *pos;
+    pos = ctx->pos;
+    n -= m;
+      ctx->event = __builtin_bswap32( ctx->item.format_64.event );
+      ctx->data = __builtin_bswap64( ctx->item.format_64.data );
+        return status;
+    } else {
+      ctx->todo -= m;
+static rtems_record_client_status consume_init(
+  const void                  *buf,
+  size_t                       n
+  while ( n > 0 ) {
+    size_t m;
+    char *pos;
+    pos = ctx->pos;
+    n -= m;
+      uint32_t magic;
+      magic = ctx->header[ 1 ];
+      switch ( ctx->header[ 0 ] ) {
+#if __BYTE_ORDER__ == __ORDER_LITTLE_ENDIAN__
+        case RTEMS_RECORD_FORMAT_LE_32:
+          ctx->consume = consume_32;
+          break;
+        case RTEMS_RECORD_FORMAT_LE_64:
+          ctx->consume = consume_64;
+          break;
+        case RTEMS_RECORD_FORMAT_BE_32:
+          ctx->consume = consume_swap_32;
+          magic = __builtin_bswap32( magic );
+          break;
+        case RTEMS_RECORD_FORMAT_BE_64:
+          ctx->consume = consume_swap_64;
+          break;
+#elif __BYTE_ORDER__ == __ORDER_BIG_ENDIAN__
+          break;
+          break;
+          break;
+          break;
+#else
+#error "unexpected __BYTE_ORDER__"
+#endif
+        default:
+          return RTEMS_RECORD_CLIENT_ERROR_UNKNOWN_FORMAT;
+      if ( magic != RTEMS_RECORD_MAGIC ) {
+        return RTEMS_RECORD_CLIENT_ERROR_INVALID_MAGIC;
+      return rtems_record_client_run( ctx, buf, n );
+    } else {
+      ctx->todo -= m;
+void rtems_record_client_init(
+  rtems_record_client_handler  handler,
+  void                        *arg
+  ctx = memset( ctx, 0, sizeof( *ctx ) );
+  ctx->to_bt_scaler = UINT64_C( 1 ) << 31;
+  ctx->handler = handler;
+  ctx->handler_arg = arg;
+  ctx->todo = sizeof( ctx->header );
+  ctx->pos = &ctx->header;
+  ctx->consume = consume_init;
+rtems_record_client_status rtems_record_client_run(
+  const void                  *buf,
+  size_t                       n
+  return ( *ctx->consume )( ctx, buf, n );
diff --git a/misc/record/record-main.c b/misc/record/record-main.c
index 0000000..e7e76ca
--- /dev/null
+++ b/misc/record/record-main.c
@@ -0,0 +1,309 @@
+ * are met:
+#include <rtems/recorddata.h>
+#include <sys/socket.h>
+#include <assert.h>
+#include <getopt.h>
+#include <stdbool.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <unistd.h>
+#include <inttypes.h>
+#include <netinet/in.h>
+#include <arpa/inet.h>
+#define THRESHOLD_IN_NS 1000000000
+static const struct option longopts[] = {
+  { "help", 0, NULL, 'h' },
+  { "host", 1, NULL, 'H' },
+  { "port", 1, NULL, 'p' },
+  { NULL, 0, NULL, 0 }
+static const char *host = "127.0.0.1";
+static uint16_t port = 1234;
+typedef struct {
+  uint64_t            ns;
+  uint32_t            cpu;
+  uint64_t            data;
+  uint64_t            counter;
+} client_item;
+typedef struct {
+  uint64_t     ns_threshold;
+  uint64_t     last_ns;
+  uint32_t     last_cpu;
+  bool         flush;
+  bool         only_one_cpu;
+  size_t       index;
+  size_t       count;
+  client_item *items;
+} client_context;
+static int item_cmp( const void *pa, const void *pb )
+  const client_item *a;
+  const client_item *b;
+  a = (const client_item *) pa;
+  b = (const client_item *) pb;
+  if ( a->ns > b->ns ) {
+    return -1;
+  } else if ( a->ns < b->ns ) {
+    return 1;
+  } else if ( a->cpu > b->cpu ) {
+    return -1;
+  } else if ( a->cpu < b->cpu ) {
+    return 1;
+  } else if ( a->counter > b->counter ) {
+    return -1;
+  } else if ( a->counter < b->counter ) {
+    return 1;
+  } else {
+    assert( 0 );
+    return 0;
+static void usage( char **argv )
+  printf(
+    "%s --host=HOST --port=PORT\n"
+    "\n"
+    "Mandatory arguments to long options are mandatory for short options too.\n"
+    "  -h, --help                 print this help text\n"
+    "  -H, --host=HOST            the host IPv4 address of the record server\n"
+    "  -p, --port=PORT            the TCP port of the record server\n",
+    argv[ 0 ]
+static int connect_client( void )
+  struct sockaddr_in in_addr;
+  int fd;
+  int rv;
+  fd = socket( PF_INET, SOCK_STREAM, 0 );
+  assert( fd >= 0 );
+  memset( &in_addr, 0, sizeof( in_addr ) );
+  in_addr.sin_family = AF_INET;
+  in_addr.sin_port = htons( port );
+  in_addr.sin_addr.s_addr = inet_addr( host );
+  rv = connect( fd, (struct sockaddr *) &in_addr, sizeof( in_addr ) );
+  assert( rv == 0 );
+  return fd;
+static void print_item( FILE *f, const client_item *item )
+  const char *event_text;
+  if ( item->ns != 0 ) {
+    uint32_t seconds;
+    uint32_t nanoseconds;
+    seconds = (uint32_t) ( item->ns / 1000000000 );
+    nanoseconds = (uint32_t) ( item->ns % 1000000000 );
+    fprintf( f, "%" PRIu32 ".%09" PRIu32 ":", seconds, nanoseconds );
+  } else {
+    fprintf( f, "*:" );
+  event_text = rtems_record_event_text( item->event );
+  if ( event_text != NULL ) {
+    fprintf( f, "%" PRIu32 ":%s:%" PRIx64 "\n", item->cpu, event_text, item->data );
+  } else {
+    fprintf( f, "%" PRIu32 ":%i:%" PRIx64 "\n", item->cpu, item->event, item->data );
+static void flush_items( client_context *cctx, uint64_t ns )
+  size_t i;
+  size_t n;
+  n = cctx->index;
+  ns_threshold = cctx->ns_threshold;
+  if ( ns >= ns_threshold ) {
+    cctx->ns_threshold = ( ( ns + THRESHOLD_IN_NS - 1 ) / THRESHOLD_IN_NS )
+      * THRESHOLD_IN_NS;
+    ns_threshold -= THRESHOLD_IN_NS;
+  } else {
+    ns_threshold = cctx->items[ n / 2 ].ns;
+  qsort( cctx->items, n, sizeof( cctx->items[ 0 ] ), item_cmp );
+  for ( i = 0; i < n; ++i ) {
+    const client_item *item;
+    item = &cctx->items[ n - i - 1 ];
+    if ( item->ns > ns_threshold ) {
+      break;
+    print_item( stdout, item );
+  cctx->index = n - i;
+static rtems_record_client_status handler(
+  uint32_t            seconds,
+  uint32_t            nanoseconds,
+  uint32_t            cpu,
+  uint64_t            data,
+  void               *arg
+  client_context *cctx;
+  client_item *item;
+  uint64_t ns;
+  bool flush;
+  cctx = arg;
+  if ( cpu != 0 ) {
+    cctx->only_one_cpu = false;
+  ns = ( (uint64_t) seconds * 1000000000 ) + nanoseconds;
+  if ( cctx->only_one_cpu ) {
+    flush = ( ns >= cctx->ns_threshold );
+  } else {
+    if ( cpu != cctx->last_cpu ) {
+      cctx->last_cpu = cpu;
+      if ( cpu == 0 ) {
+        flush = ( cctx->flush && cctx->last_ns >= cctx->ns_threshold );
+        cctx->flush = true;
+      } else {
+        flush = false;
+        cctx->flush = ( cctx->flush && cctx->last_ns >= cctx->ns_threshold );
+    } else {
+      flush = false;
+  if (
+    ns != 0
+      && event != RTEMS_RECORD_UPTIME_LOW
+      && event != RTEMS_RECORD_UPTIME_HIGH
+    cctx->last_ns = ns;
+    item = &cctx->items[ cctx->index ];
+    item->ns = ns;
+    item->cpu = cpu;
+    item->event = event;
+    item->data = data;
+    ++cctx->index;
+  if ( flush || cctx->index == cctx->count ) {
+    flush_items( cctx, ns );
+int main( int argc, char **argv )
+  rtems_record_client_context ctx;
+  client_context cctx;
+  int fd;
+  int rv;
+  int opt;
+  int longindex;
+  while (
+    ( opt = getopt_long( argc, argv, "hH:p:", &longopts[0], &longindex ) ) != -1
+    switch ( opt ) {
+      case 'h':
+        usage( argv );
+        exit( EXIT_SUCCESS );
+        break;
+      case 'H':
+        host = optarg;
+        break;
+      case 'p':
+        port = (uint16_t) strtoul( optarg, NULL, 10 );
+        break;
+      default:
+        exit( EXIT_FAILURE );
+        break;
+  memset( &cctx, 0, sizeof( cctx ) );
+  cctx.only_one_cpu = true;
+  cctx.ns_threshold = 2 * THRESHOLD_IN_NS;
+  cctx.count = 32 * 1024 * 1024;
+  cctx.items = calloc( cctx.count, sizeof( cctx.items[ 0 ] ) );
+  assert( cctx.items != NULL );
+  fd = connect_client();
+  rtems_record_client_init( &ctx, handler, &cctx );
+  while ( true ) {
+    int buf[ 1024 ];
+    ssize_t n;
+    n = recv( fd, buf, sizeof( buf ), 0 );
+    if ( n >= 0 ) {
+      rtems_record_client_run( &ctx, buf, (size_t) n );
+    } else {
+      break;
+  rv = close( fd );
+  return 0;
diff --git a/misc/record/record-text.c b/misc/record/record-text.c
index 0000000..f8173ce
--- /dev/null
+++ b/misc/record/record-text.c
@@ -0,0 +1,197 @@
+ * are met:
+#if HAVE_CONFIG_H
+#endif
+#include <stddef.h>
+static const char * const event_text[] = {
+  [ RTEMS_RECORD_EMPTY ] = "EMPTY",
+  [ RTEMS_RECORD_VERSION ] = "VERSION",
+  [ RTEMS_RECORD_ACCEPT ] = "ACCEPT",
+  [ RTEMS_RECORD_BIND ] = "BIND",
+  [ RTEMS_RECORD_BUFFER ] = "BUFFER",
+  [ RTEMS_RECORD_CHOWN ] = "CHOWN",
+  [ RTEMS_RECORD_CLOSE ] = "CLOSE",
+  [ RTEMS_RECORD_CONNECT ] = "CONNECT",
+  [ RTEMS_RECORD_COUNT ] = "COUNT",
+  [ RTEMS_RECORD_ETHER_INPUT ] = "ETHER_INPUT",
+  [ RTEMS_RECORD_ETHER_OUTPUT ] = "ETHER_OUTPUT",
+  [ RTEMS_RECORD_FCHMOD ] = "FCHMOD",
+  [ RTEMS_RECORD_FCNTL ] = "FCNTL",
+  [ RTEMS_RECORD_FDATASYNC ] = "FDATASYNC",
+  [ RTEMS_RECORD_FREQUENCY ] = "FREQUENCY",
+  [ RTEMS_RECORD_FSTAT ] = "FSTAT",
+  [ RTEMS_RECORD_FSYNC ] = "FSYNC",
+  [ RTEMS_RECORD_FTRUNCATE ] = "FTRUNCATE",
+  [ RTEMS_RECORD_GIT_HASH ] = "GIT_HASH",
+  [ RTEMS_RECORD_HEAD ] = "HEAD",
+  [ RTEMS_RECORD_HEAP_ALLOC ] = "HEAP_ALLOC",
+  [ RTEMS_RECORD_HEAP_FREE ] = "HEAP_FREE",
+  [ RTEMS_RECORD_HEAP_SIZE ] = "HEAP_SIZE",
+  [ RTEMS_RECORD_HEAP_USAGE ] = "HEAP_USAGE",
+  [ RTEMS_RECORD_INTERUPT_BEGIN ] = "INTERUPT_BEGIN",
+  [ RTEMS_RECORD_INTERUPT_END ] = "INTERUPT_END",
+  [ RTEMS_RECORD_INTERUPT_INSTALL ] = "INTERUPT_INSTALL",
+  [ RTEMS_RECORD_INTERUPT_REMOVE ] = "INTERUPT_REMOVE",
+  [ RTEMS_RECORD_IOCTL ] = "IOCTL",
+  [ RTEMS_RECORD_IP6_INPUT ] = "IP6_INPUT",
+  [ RTEMS_RECORD_IP6_OUTPUT ] = "IP6_OUTPUT",
+  [ RTEMS_RECORD_IP_INPUT ] = "IP_INPUT",
+  [ RTEMS_RECORD_IP_OUTPUT ] = "IP_OUTPUT",
+  [ RTEMS_RECORD_KEVENT ] = "KEVENT",
+  [ RTEMS_RECORD_KQUEUE ] = "KQUEUE",
+  [ RTEMS_RECORD_LENGTH ] = "LENGTH",
+  [ RTEMS_RECORD_LINK ] = "LINK",
+  [ RTEMS_RECORD_LSEEK ] = "LSEEK",
+  [ RTEMS_RECORD_MKNOD ] = "MKNOD",
+  [ RTEMS_RECORD_MMAP ] = "MMAP",
+  [ RTEMS_RECORD_MOUNT ] = "MOUNT",
+  [ RTEMS_RECORD_OPEN ] = "OPEN",
+  [ RTEMS_RECORD_OVERFLOW ] = "OVERFLOW",
+  [ RTEMS_RECORD_PAGE_ALLOC ] = "PAGE_ALLOC",
+  [ RTEMS_RECORD_PAGE_FREE ] = "PAGE_FREE",
+  [ RTEMS_RECORD_POLL ] = "POLL",
+  [ RTEMS_RECORD_PROCESSOR ] = "PROCESSOR",
+  [ RTEMS_RECORD_PROCESSOR_MAXIMUM ] = "PROCESSOR_MAXIMUM",
+  [ RTEMS_RECORD_READ ] = "READ",
+  [ RTEMS_RECORD_READLINK ] = "READLINK",
+  [ RTEMS_RECORD_READV ] = "READV",
+  [ RTEMS_RECORD_RECV ] = "RECV",
+  [ RTEMS_RECORD_RECVFROM ] = "RECVFROM",
+  [ RTEMS_RECORD_RECVMSG ] = "RECVMSG",
+  [ RTEMS_RECORD_RENAME ] = "RENAME",
+  [ RTEMS_RECORD_RTEMS_BARRIER_CREATE ] = "RTEMS_BARRIER_CREATE",
+  [ RTEMS_RECORD_RTEMS_BARRIER_DELETE ] = "RTEMS_BARRIER_DELETE",
+  [ RTEMS_RECORD_RTEMS_BARRIER_RELEASE ] = "RTEMS_BARRIER_RELEASE",
+  [ RTEMS_RECORD_RTEMS_BARRIER_WAIT ] = "RTEMS_BARRIER_WAIT",
+  [ RTEMS_RECORD_RTEMS_EVENT_RECEIVE ] = "RTEMS_EVENT_RECEIVE",
+  [ RTEMS_RECORD_RTEMS_EVENT_SEND ] = "RTEMS_EVENT_SEND",
+  [ RTEMS_RECORD_RTEMS_EVENT_SYSTEM_RECEIVE ] = "RTEMS_EVENT_SYSTEM_RECEIVE",
+  [ RTEMS_RECORD_RTEMS_EVENT_SYSTEM_SEND ] = "RTEMS_EVENT_SYSTEM_SEND",
+  [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_BROADCAST ] = "RTEMS_MESSAGE_QUEUE_BROADCAST",
+  [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_CREATE ] = "RTEMS_MESSAGE_QUEUE_CREATE",
+  [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_DELETE ] = "RTEMS_MESSAGE_QUEUE_DELETE",
+  [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_FLUSH ] = "RTEMS_MESSAGE_QUEUE_FLUSH",
+  [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_RECEIVE ] = "RTEMS_MESSAGE_QUEUE_RECEIVE",
+  [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_SEND ] = "RTEMS_MESSAGE_QUEUE_SEND",
+  [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_URGENT ] = "RTEMS_MESSAGE_QUEUE_URGENT",
+  [ RTEMS_RECORD_RTEMS_PARTITION_CREATE ] = "RTEMS_PARTITION_CREATE",
+  [ RTEMS_RECORD_RTEMS_PARTITION_DELETE ] = "RTEMS_PARTITION_DELETE",
+  [ RTEMS_RECORD_RTEMS_PARTITION_GET_BUFFER ] = "RTEMS_PARTITION_GET_BUFFER",
+  [ RTEMS_RECORD_RTEMS_PARTITION_RETURN_BUFFER ] = "RTEMS_PARTITION_RETURN_BUFFER",
+  [ RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CANCEL ] = "RTEMS_RATE_MONOTONIC_CANCEL",
+  [ RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CREATE ] = "RTEMS_RATE_MONOTONIC_CREATE",
+  [ RTEMS_RECORD_RTEMS_RATE_MONOTONIC_DELETE ] = "RTEMS_RATE_MONOTONIC_DELETE",
+  [ RTEMS_RECORD_RTEMS_RATE_MONOTONIC_PERIOD ] = "RTEMS_RATE_MONOTONIC_PERIOD",
+  [ RTEMS_RECORD_RTEMS_SEMAPHORE_CREATE ] = "RTEMS_SEMAPHORE_CREATE",
+  [ RTEMS_RECORD_RTEMS_SEMAPHORE_DELETE ] = "RTEMS_SEMAPHORE_DELETE",
+  [ RTEMS_RECORD_RTEMS_SEMAPHORE_FLUSH ] = "RTEMS_SEMAPHORE_FLUSH",
+  [ RTEMS_RECORD_RTEMS_SEMAPHORE_OBTAIN ] = "RTEMS_SEMAPHORE_OBTAIN",
+  [ RTEMS_RECORD_RTEMS_SEMAPHORE_RELEASE ] = "RTEMS_SEMAPHORE_RELEASE",
+  [ RTEMS_RECORD_RTEMS_TIMER_CANCEL ] = "RTEMS_TIMER_CANCEL",
+  [ RTEMS_RECORD_RTEMS_TIMER_CREATE ] = "RTEMS_TIMER_CREATE",
+  [ RTEMS_RECORD_RTEMS_TIMER_DELETE ] = "RTEMS_TIMER_DELETE",
+  [ RTEMS_RECORD_RTEMS_TIMER_FIRE_AFTER ] = "RTEMS_TIMER_FIRE_AFTER",
+  [ RTEMS_RECORD_RTEMS_TIMER_FIRE_WHEN ] = "RTEMS_TIMER_FIRE_WHEN",
+  [ RTEMS_RECORD_RTEMS_TIMER_RESET ] = "RTEMS_TIMER_RESET",
+  [ RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_AFTER ] = "RTEMS_TIMER_SERVER_FIRE_AFTER",
+  [ RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_WHEN ] = "RTEMS_TIMER_SERVER_FIRE_WHEN",
+  [ RTEMS_RECORD_SELECT ] = "SELECT",
+  [ RTEMS_RECORD_SEND ] = "SEND",
+  [ RTEMS_RECORD_SENDMSG ] = "SENDMSG",
+  [ RTEMS_RECORD_SENDTO ] = "SENDTO",
+  [ RTEMS_RECORD_SOCKET ] = "SOCKET",
+  [ RTEMS_RECORD_STATVFS ] = "STATVFS",
+  [ RTEMS_RECORD_SYMLINK ] = "SYMLINK",
+  [ RTEMS_RECORD_TAIL ] = "TAIL",
+  [ RTEMS_RECORD_TCP_INPUT ] = "TCP_INPUT",
+  [ RTEMS_RECORD_TCP_OUTPUT ] = "TCP_OUTPUT",
+  [ RTEMS_RECORD_THREAD_BEGIN ] = "THREAD_BEGIN",
+  [ RTEMS_RECORD_THREAD_CREATE ] = "THREAD_CREATE",
+  [ RTEMS_RECORD_THREAD_DELETE ] = "THREAD_DELETE",
+  [ RTEMS_RECORD_THREAD_EXIT ] = "THREAD_EXIT",
+  [ RTEMS_RECORD_THREAD_EXITTED ] = "THREAD_EXITTED",
+  [ RTEMS_RECORD_THREAD_ID ] = "THREAD_ID",
+  [ RTEMS_RECORD_THREAD_PRIO_CURRENT_HIGH ] = "THREAD_PRIO_CURRENT_HIGH",
+  [ RTEMS_RECORD_THREAD_PRIO_CURRENT_LOW ] = "THREAD_PRIO_CURRENT_LOW",
+  [ RTEMS_RECORD_THREAD_PRIO_REAL_HIGH ] = "THREAD_PRIO_REAL_HIGH",
+  [ RTEMS_RECORD_THREAD_PRIO_REAL_LOW ] = "THREAD_PRIO_REAL_LOW",
+  [ RTEMS_RECORD_THREAD_QUEUE_ENQUEUE ] = "THREAD_QUEUE_ENQUEUE",
+  [ RTEMS_RECORD_THREAD_QUEUE_ENQUEUE_STICKY ] = "THREAD_QUEUE_ENQUEUE_STICKY",
+  [ RTEMS_RECORD_THREAD_QUEUE_EXTRACT ] = "THREAD_QUEUE_EXTRACT",
+  [ RTEMS_RECORD_THREAD_QUEUE_SURRENDER ] = "THREAD_QUEUE_SURRENDER",
+  [ RTEMS_RECORD_THREAD_QUEUE_SURRENDER_STICKY ] = "THREAD_QUEUE_SURRENDER_STICKY",
+  [ RTEMS_RECORD_THREAD_RESTART ] = "THREAD_RESTART",
+  [ RTEMS_RECORD_THREAD_STACK_CURRENT ] = "THREAD_STACK_CURRENT",
+  [ RTEMS_RECORD_THREAD_STACK_SIZE ] = "THREAD_STACK_SIZE",
+  [ RTEMS_RECORD_THREAD_STACK_USAGE ] = "THREAD_STACK_USAGE",
+  [ RTEMS_RECORD_THREAD_START ] = "THREAD_START",
+  [ RTEMS_RECORD_THREAD_STATE_CLEAR ] = "THREAD_STATE_CLEAR",
+  [ RTEMS_RECORD_THREAD_STATE_SET ] = "THREAD_STATE_SET",
+  [ RTEMS_RECORD_THREAD_SWITCH_IN ] = "THREAD_SWITCH_IN",
+  [ RTEMS_RECORD_THREAD_SWITCH_OUT ] = "THREAD_SWITCH_OUT",
+  [ RTEMS_RECORD_THREAD_TERMINATE ] = "THREAD_TERMINATE",
+  [ RTEMS_RECORD_UDP_INPUT ] = "UDP_INPUT",
+  [ RTEMS_RECORD_UDP_OUTPUT ] = "UDP_OUTPUT",
+  [ RTEMS_RECORD_UMA_ALLOC_PTR ] = "UMA_ALLOC_PTR",
+  [ RTEMS_RECORD_UMA_ALLOC_ZONE ] = "UMA_ALLOC_ZONE",
+  [ RTEMS_RECORD_UMA_FREE_PTR ] = "UMA_FREE_PTR",
+  [ RTEMS_RECORD_UMA_FREE_ZONE ] = "UMA_FREE_ZONE",
+  [ RTEMS_RECORD_UNLINK ] = "UNLINK",
+  [ RTEMS_RECORD_UNMOUNT ] = "UNMOUNT",
+  [ RTEMS_RECORD_UPTIME_HIGH ] = "UPTIME_HIGH",
+  [ RTEMS_RECORD_UPTIME_LOW ] = "UPTIME_LOW",
+  [ RTEMS_RECORD_WORKSPACE_ALLOC ] = "WORKSPACE_ALLOC",
+  [ RTEMS_RECORD_WORKSPACE_FREE ] = "WORKSPACE_FREE",
+  [ RTEMS_RECORD_WORKSPACE_SIZE ] = "WORKSPACE_SIZE",
+  [ RTEMS_RECORD_WORKSPACE_USAGE ] = "WORKSPACE_USAGE",
+  [ RTEMS_RECORD_WRITE ] = "WRITE",
+  [ RTEMS_RECORD_WRITEV ] = "WRITEV"
+const char *rtems_record_event_text( rtems_record_event event )
+  size_t n;
+  n = event;
+  if ( n < sizeof( event_text ) / sizeof( event_text[ 0 ] ) ) {
+    return event_text[ n ];
+  return NULL;
diff --git a/misc/record/rtems/recordclient.h b/misc/record/rtems/recordclient.h
index 0000000..61ef967
--- /dev/null
+++ b/misc/record/rtems/recordclient.h
@@ -0,0 +1,139 @@
+ * are met:
+#ifndef _RTEMS_RECORDCLIENT_H
+#define _RTEMS_RECORDCLIENT_H
+#include "recorddata.h"
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @addtogroup RTEMSRecord
+#define RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT 32
+typedef enum {
+  RTEMS_RECORD_CLIENT_SUCCESS,
+  RTEMS_RECORD_CLIENT_ERROR_INVALID_MAGIC,
+  RTEMS_RECORD_CLIENT_ERROR_UNKNOWN_FORMAT,
+  RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_VERSION,
+  RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_CPU
+} rtems_record_client_status;
+typedef rtems_record_client_status ( *rtems_record_client_handler )(
+  uint32_t            seconds,
+  uint32_t            cpu,
+  uint64_t            data,
+  void               *arg
+typedef struct {
+  struct {
+    uint64_t bt;
+    uint32_t time_at_bt;
+    uint32_t time_last;
+    uint32_t time_accumulated;
+  } uptime;
+  uint32_t tail[ 2 ];
+  uint32_t head[ 2 ];
+  size_t index;
+} rtems_record_client_per_cpu;
+typedef struct rtems_record_client_context {
+  uint64_t to_bt_scaler;
+  rtems_record_client_per_cpu per_cpu[ RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT ];
+  uint64_t data;
+  uint32_t cpu;
+  uint32_t event;
+  uint32_t count;
+  union {
+    rtems_record_item_32 format_32;
+    rtems_record_item_64 format_64;
+  } item;
+  size_t todo;
+  void *pos;
+  rtems_record_client_status ( *consume )(
+    struct rtems_record_client_context *,
+    const void *,
+    size_t
+  rtems_record_client_handler handler;
+  void *handler_arg;
+  uint32_t header[ 2 ];
+} rtems_record_client_context;
+ * @brief Initializes a record client.
+ * The record client consumes a record item stream produces by the record
+ * server.
+ * @param ctx The record client context to initialize.
+ * @param handler The handler is invoked for each received record item.
+ * @param arg The handler argument.
+  void                        *arg
+ * @brief Runs the record client to consume new stream data.
+ * @param ctx The record client context.
+ * @param buf The buffer with new stream data.
+ * @param n The size of the buffer.
+  const void                  *buf,
+  size_t                       n
+#ifdef __cplusplus
+#endif /* _RTEMS_RECORDCLIENT_H */
diff --git a/misc/record/rtems/recorddata.h b/misc/record/rtems/recorddata.h
index 0000000..5879980
--- /dev/null
+++ b/misc/record/rtems/recorddata.h
@@ -0,0 +1,317 @@
+ * are met:
+#ifndef _RTEMS_RECORDDATA_H
+#define _RTEMS_RECORDDATA_H
+#include <stdint.h>
+#ifdef __cplusplus
+extern "C" {
+ * @defgroup RTEMSRecord Event Recording
+ * @brief Low-level event recording support.
+ * @brief The record version.
+ * The record version reflects the record event definitions.  It is reported by
+ * the RTEMS_RECORD_VERSION event.
+#define RTEMS_RECORD_THE_VERSION 1
+ * @brief The items are in 32-bit little-endian format.
+#define RTEMS_RECORD_FORMAT_LE_32 0x11111111
+ * @brief The items are in 64-bit little-endian format.
+#define RTEMS_RECORD_FORMAT_LE_64 0x22222222
+ * @brief The items are in 32-bit big-endian format.
+#define RTEMS_RECORD_FORMAT_BE_32 0x33333333
+ * @brief The items are in 64-bit big-endian format.
+#define RTEMS_RECORD_FORMAT_BE_64 0x44444444
+ * @brief Magic number to identify a record item stream.
+ * This is a random number.
+#define RTEMS_RECORD_MAGIC 0x82e14ec1
+ * @brief The record events.
+typedef enum {
+  /* There are 512 events reserved for the system */
+  RTEMS_RECORD_EMPTY,
+  RTEMS_RECORD_VERSION,
+   * Keep the following system events in lexicographical order, increment
+   * RTEMS_RECORD_THE_VERSION after each change.
+  RTEMS_RECORD_ACCEPT,
+  RTEMS_RECORD_BIND,
+  RTEMS_RECORD_BUFFER,
+  RTEMS_RECORD_CHOWN,
+  RTEMS_RECORD_CLOSE,
+  RTEMS_RECORD_CONNECT,
+  RTEMS_RECORD_COUNT,
+  RTEMS_RECORD_ETHER_INPUT,
+  RTEMS_RECORD_ETHER_OUTPUT,
+  RTEMS_RECORD_FCHMOD,
+  RTEMS_RECORD_FCNTL,
+  RTEMS_RECORD_FDATASYNC,
+  RTEMS_RECORD_FREQUENCY,
+  RTEMS_RECORD_FSTAT,
+  RTEMS_RECORD_FSYNC,
+  RTEMS_RECORD_FTRUNCATE,
+  RTEMS_RECORD_GIT_HASH,
+  RTEMS_RECORD_HEAD,
+  RTEMS_RECORD_HEAP_ALLOC,
+  RTEMS_RECORD_HEAP_FREE,
+  RTEMS_RECORD_HEAP_SIZE,
+  RTEMS_RECORD_HEAP_USAGE,
+  RTEMS_RECORD_INTERUPT_BEGIN,
+  RTEMS_RECORD_INTERUPT_END,
+  RTEMS_RECORD_INTERUPT_INSTALL,
+  RTEMS_RECORD_INTERUPT_REMOVE,
+  RTEMS_RECORD_IOCTL,
+  RTEMS_RECORD_IP6_INPUT,
+  RTEMS_RECORD_IP6_OUTPUT,
+  RTEMS_RECORD_IP_INPUT,
+  RTEMS_RECORD_IP_OUTPUT,
+  RTEMS_RECORD_KEVENT,
+  RTEMS_RECORD_KQUEUE,
+  RTEMS_RECORD_LENGTH,
+  RTEMS_RECORD_LINK,
+  RTEMS_RECORD_LSEEK,
+  RTEMS_RECORD_MKNOD,
+  RTEMS_RECORD_MMAP,
+  RTEMS_RECORD_MOUNT,
+  RTEMS_RECORD_OPEN,
+  RTEMS_RECORD_PAGE_ALLOC,
+  RTEMS_RECORD_PAGE_FREE,
+  RTEMS_RECORD_POLL,
+  RTEMS_RECORD_PROCESSOR,
+  RTEMS_RECORD_PROCESSOR_MAXIMUM,
+  RTEMS_RECORD_READ,
+  RTEMS_RECORD_READLINK,
+  RTEMS_RECORD_READV,
+  RTEMS_RECORD_RECV,
+  RTEMS_RECORD_RECVFROM,
+  RTEMS_RECORD_RECVMSG,
+  RTEMS_RECORD_RENAME,
+  RTEMS_RECORD_RTEMS_BARRIER_CREATE,
+  RTEMS_RECORD_RTEMS_BARRIER_DELETE,
+  RTEMS_RECORD_RTEMS_BARRIER_RELEASE,
+  RTEMS_RECORD_RTEMS_BARRIER_WAIT,
+  RTEMS_RECORD_RTEMS_EVENT_RECEIVE,
+  RTEMS_RECORD_RTEMS_EVENT_SEND,
+  RTEMS_RECORD_RTEMS_EVENT_SYSTEM_RECEIVE,
+  RTEMS_RECORD_RTEMS_EVENT_SYSTEM_SEND,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_BROADCAST,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_CREATE,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_DELETE,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_FLUSH,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_RECEIVE,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_SEND,
+  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_URGENT,
+  RTEMS_RECORD_RTEMS_PARTITION_CREATE,
+  RTEMS_RECORD_RTEMS_PARTITION_DELETE,
+  RTEMS_RECORD_RTEMS_PARTITION_GET_BUFFER,
+  RTEMS_RECORD_RTEMS_PARTITION_RETURN_BUFFER,
+  RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CANCEL,
+  RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CREATE,
+  RTEMS_RECORD_RTEMS_RATE_MONOTONIC_DELETE,
+  RTEMS_RECORD_RTEMS_RATE_MONOTONIC_PERIOD,
+  RTEMS_RECORD_RTEMS_SEMAPHORE_CREATE,
+  RTEMS_RECORD_RTEMS_SEMAPHORE_DELETE,
+  RTEMS_RECORD_RTEMS_SEMAPHORE_FLUSH,
+  RTEMS_RECORD_RTEMS_SEMAPHORE_OBTAIN,
+  RTEMS_RECORD_RTEMS_SEMAPHORE_RELEASE,
+  RTEMS_RECORD_RTEMS_TIMER_CANCEL,
+  RTEMS_RECORD_RTEMS_TIMER_CREATE,
+  RTEMS_RECORD_RTEMS_TIMER_DELETE,
+  RTEMS_RECORD_RTEMS_TIMER_FIRE_AFTER,
+  RTEMS_RECORD_RTEMS_TIMER_FIRE_WHEN,
+  RTEMS_RECORD_RTEMS_TIMER_RESET,
+  RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_AFTER,
+  RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_WHEN,
+  RTEMS_RECORD_SELECT,
+  RTEMS_RECORD_SEND,
+  RTEMS_RECORD_SENDMSG,
+  RTEMS_RECORD_SENDTO,
+  RTEMS_RECORD_SOCKET,
+  RTEMS_RECORD_STATVFS,
+  RTEMS_RECORD_SYMLINK,
+  RTEMS_RECORD_TAIL,
+  RTEMS_RECORD_TCP_INPUT,
+  RTEMS_RECORD_TCP_OUTPUT,
+  RTEMS_RECORD_THREAD_BEGIN,
+  RTEMS_RECORD_THREAD_CREATE,
+  RTEMS_RECORD_THREAD_DELETE,
+  RTEMS_RECORD_THREAD_EXIT,
+  RTEMS_RECORD_THREAD_EXITTED,
+  RTEMS_RECORD_THREAD_ID,
+  RTEMS_RECORD_THREAD_PRIO_CURRENT_HIGH,
+  RTEMS_RECORD_THREAD_PRIO_CURRENT_LOW,
+  RTEMS_RECORD_THREAD_PRIO_REAL_HIGH,
+  RTEMS_RECORD_THREAD_PRIO_REAL_LOW,
+  RTEMS_RECORD_THREAD_QUEUE_ENQUEUE,
+  RTEMS_RECORD_THREAD_QUEUE_ENQUEUE_STICKY,
+  RTEMS_RECORD_THREAD_QUEUE_EXTRACT,
+  RTEMS_RECORD_THREAD_QUEUE_SURRENDER,
+  RTEMS_RECORD_THREAD_QUEUE_SURRENDER_STICKY,
+  RTEMS_RECORD_THREAD_RESTART,
+  RTEMS_RECORD_THREAD_STACK_CURRENT,
+  RTEMS_RECORD_THREAD_STACK_SIZE,
+  RTEMS_RECORD_THREAD_STACK_USAGE,
+  RTEMS_RECORD_THREAD_START,
+  RTEMS_RECORD_THREAD_STATE_CLEAR,
+  RTEMS_RECORD_THREAD_STATE_SET,
+  RTEMS_RECORD_THREAD_SWITCH_IN,
+  RTEMS_RECORD_THREAD_SWITCH_OUT,
+  RTEMS_RECORD_THREAD_TERMINATE,
+  RTEMS_RECORD_UDP_INPUT,
+  RTEMS_RECORD_UDP_OUTPUT,
+  RTEMS_RECORD_UMA_ALLOC_PTR,
+  RTEMS_RECORD_UMA_ALLOC_ZONE,
+  RTEMS_RECORD_UMA_FREE_PTR,
+  RTEMS_RECORD_UMA_FREE_ZONE,
+  RTEMS_RECORD_UNLINK,
+  RTEMS_RECORD_UNMOUNT,
+  RTEMS_RECORD_UPTIME_HIGH,
+  RTEMS_RECORD_UPTIME_LOW,
+  RTEMS_RECORD_WORKSPACE_ALLOC,
+  RTEMS_RECORD_WORKSPACE_FREE,
+  RTEMS_RECORD_WORKSPACE_SIZE,
+  RTEMS_RECORD_WORKSPACE_USAGE,
+  RTEMS_RECORD_WRITE,
+  RTEMS_RECORD_WRITEV,
+  /* There are 512 events reserved for the user */
+  RTEMS_RECORD_USER = 512,
+  RTEMS_RECORD_LAST = 1023
+} rtems_record_event;
+ * @brief Bits in the record item event member reserved for the actual event.
+#define RTEMS_RECORD_EVENT_BITS 10
+ * @brief Bits in the record item event member reserved for the time of the
+ * event.
+#define RTEMS_RECORD_TIME_BITS 22
+ * @brief Builds a time event for the specified time stamp and event.
+ * The events are stored in the record item with a time stamp.  There are 22
+ * bits allocated to the time stamp and 10 bits allocated to the event.  The 22
+ * bits are enough to get reliable time stamps on a system with a 4GHz CPU
+ * counter and a 1000Hz clock tick.
+#define RTEMS_RECORD_TIME_EVENT( time, event ) \
+  ( ( ( time ) << RTEMS_RECORD_EVENT_BITS ) | ( event ) )
+ * @brief Gets the time of a time event.
+#define RTEMS_RECORD_GET_TIME( time_event ) \
+  ( ( time_event ) >> RTEMS_RECORD_EVENT_BITS )
+ * @brief Gets the event of a time event.
+#define RTEMS_RECORD_GET_EVENT( time_event ) \
+  ( ( time_event ) & ( ( 1U << RTEMS_RECORD_EVENT_BITS ) - 1U ) )
+ * @brief The record data integer type.
+ * It is big enough to store 32-bit integers and pointers.
+typedef unsigned long rtems_record_data;
+ * @brief The native record item.
+typedef struct __attribute__((__packed__)) {
+  uint32_t          event;
+  rtems_record_data data;
+} rtems_record_item;
+ * @brief The 32-bit format record item.
+typedef struct {
+  uint32_t event;
+  uint32_t data;
+} rtems_record_item_32;
+ * @brief The 64-bit format record item.
+  uint32_t event;
+  uint64_t data;
+} rtems_record_item_64;
+const char *rtems_record_event_text( rtems_record_event event );
+#ifdef __cplusplus
+#endif /* _RTEMS_RECORDDATA_H */
diff --git a/misc/wscript b/misc/wscript
index 95c7bde..d5070c1 100644
--- a/misc/wscript
+++ b/misc/wscript
@@ -67,5 +67,15 @@ def build(bld):
                 cflags = conf['cflags'] + conf['warningflags'],
                 linkflags = conf['linkflags'])
+    # Build rtems-record
+    bld.program(target = 'rtems-record',
+                source = ['record/record-client.c', 'record/record-main.c', 'record/record-text.c'],
+                includes = ['record'],
+                defines = defines,
+                cflags = conf['cflags'] + conf['warningflags'],
+                linkflags = conf['linkflags'])
 def tags(ctx):
     ctx.exec_command('etags $(find . -name \*.[sSch])', shell = True)
2.16.4
