[PATCH 1/2] c-user: Add event recording configuration
Sebastian Huber
Wed Jan 30 10:40:49 UTC 2019
Update #3665.
c-user/configuring_a_system.rst | 58 +++++++++++++++++++++++++++++++++++++++++
1 file changed, 58 insertions(+)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index a01053c..1e7b6cc 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -4813,6 +4813,64 @@ Note that selecting ``PCI_LIB_STATIC`` or ``PCI_LIB_PERIPHERAL`` but not
defining ``pci_hb`` will reuslt in link errors. Note also that in these modes
Plug & Play is not performed.
+Event Recording
+.. index:: CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
+.. _CONFIGURE_RECORD_PER_PROCESSOR_ITEMS:
+CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
+CONSTANT:
+ ``CONFIGURE_RECORD_PER_PROCESSOR_ITEMS``
+DATA TYPE:
+ Unsigned integer (``unsigned int``).
+RANGE:
+ A power of two greater than or equal to 16.
+DEFAULT VALUE:
+ This is not defined by default.
+DESCRIPTION:
+ If defined, then a record item buffer of the specified item count is
+ statically allocated for each configured processor
+ (:ref:`CONFIGURE_MAXIMUM_PROCESSORS <CONFIGURE_MAXIMUM_PROCESSORS>`).
+NOTES:
+ None.
+.. index:: CONFIGURE_RECORD_EXTENSIONS_ENABLED
+.. _CONFIGURE_RECORD_EXTENSIONS_ENABLED:
+CONFIGURE_RECORD_EXTENSIONS_ENABLED
+CONSTANT:
+ ``CONFIGURE_RECORD_EXTENSIONS_ENABLED``
+DATA TYPE:
+ Boolean feature macro.
+RANGE:
+ Defined or undefined.
+DEFAULT VALUE:
+DESCRIPTION:
+ If defined and :ref:`CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
+ <CONFIGURE_RECORD_PER_PROCESSOR_ITEMS>` is also defined properly, then the
+ record extensions are enabled.
+NOTES:
+ The record extensions capture thread create, start, restart, delete,
+ switch, begin, exitted and terminate events.
Go Tasks
2.16.4
