[PATCH] fs: Add struct dirent::d_type support
Sebastian Huber
Thu Jan 31 13:01:49 UTC 2019
cpukit/libfs/src/dosfs/msdos_dir.c | 11 ++++
cpukit/libfs/src/imfs/imfs_dir_default.c | 3 ++
cpukit/libfs/src/jffs2/include/linux/fs.h | 5 ++
cpukit/libfs/src/jffs2/src/fs-rtems.c | 11 ++--
cpukit/libfs/src/nfsclient/src/nfs.c | 3 ++
testsuites/fstests/fsscandir01/init.c | 89 +++++++++++++++++++++----------
6 files changed, 91 insertions(+), 31 deletions(-)
diff --git a/cpukit/libfs/src/dosfs/msdos_dir.c b/cpukit/libfs/src/dosfs/msdos_dir.c
index a13caafa7e..fee6491c7d 100644
--- a/cpukit/libfs/src/dosfs/msdos_dir.c
+++ b/cpukit/libfs/src/dosfs/msdos_dir.c
@@ -236,6 +236,17 @@ msdos_dir_read(rtems_libio_t *iop, void *buffer, size_t count)
continue;
+#ifdef DT_DIR
+ if ((*MSDOS_DIR_ATTR(entry)) & MSDOS_ATTR_DIRECTORY)
+ tmp_dirent.d_type = DT_DIR;
+ else
+ tmp_dirent.d_type = DT_REG;
+#endif
* Move the entry to the return buffer
diff --git a/cpukit/libfs/src/imfs/imfs_dir_default.c b/cpukit/libfs/src/imfs/imfs_dir_default.c
index 03ef115301..7bb4f378e1 100644
--- a/cpukit/libfs/src/imfs/imfs_dir_default.c
+++ b/cpukit/libfs/src/imfs/imfs_dir_default.c
@@ -74,6 +74,9 @@ static ssize_t IMFS_dir_read(
dir_ent->d_off = current_entry;
dir_ent->d_reclen = sizeof( *dir_ent );
dir_ent->d_ino = IMFS_node_to_ino( imfs_node );
+#ifdef DT_DIR
+ dir_ent->d_type = IFTODT( imfs_node->st_mode );
+#endif
dir_ent->d_namlen =
MIN( imfs_node->namelen, sizeof( dir_ent->d_name ) - 1 );
dir_ent->d_name[ dir_ent->d_namlen ] = '\0';
diff --git a/cpukit/libfs/src/jffs2/include/linux/fs.h b/cpukit/libfs/src/jffs2/include/linux/fs.h
index 8da9880b13..a638e7b6bf 100644
--- a/cpukit/libfs/src/jffs2/include/linux/fs.h
+++ b/cpukit/libfs/src/jffs2/include/linux/fs.h
@@ -3,12 +3,17 @@
#include <linux/stat.h>
#include <sys/types.h>
+#include <sys/dirent.h>
#include <sys/time.h>
+#ifdef DT_DIR
+#define RTEMS_JFFS2_HAVE_D_TYPE
+#else
#define DT_UNKNOWN 0
#define DT_DIR 4
#define DT_REG 8
#define DT_LNK 10
+#endif
#define ATTR_MODE (1U << 0)
#define ATTR_UID (1U << 1)
diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c b/cpukit/libfs/src/jffs2/src/fs-rtems.c
index 17a4985607..aae208ccef 100644
--- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
+++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
@@ -423,7 +423,7 @@ static int rtems_jffs2_fstat(
return 0;
-static int rtems_jffs2_fill_dirent(struct dirent *de, off_t off, uint32_t ino, const char *name)
+static int rtems_jffs2_fill_dirent(struct dirent *de, off_t off, uint32_t ino, const char *name, unsigned char type)
int eno = 0;
size_t len;
@@ -433,6 +433,9 @@ static int rtems_jffs2_fill_dirent(struct dirent *de, off_t off, uint32_t ino, c
de->d_off = off * sizeof(*de);
de->d_reclen = sizeof(*de);
de->d_ino = ino;
+#ifdef RTEMS_JFFS2_HAVE_D_TYPE
+ de->d_type = type;
+#endif
len = strlen(name);
de->d_namlen = len;
@@ -466,14 +469,14 @@ static ssize_t rtems_jffs2_dir_read(rtems_libio_t *iop, void *buf, size_t len)
off = begin;
if (off == 0 && off < end) {
- eno = rtems_jffs2_fill_dirent(de, off, inode->i_ino, ".");
+ eno = rtems_jffs2_fill_dirent(de, off, inode->i_ino, ".", DT_DIR);
assert(eno == 0);
++off;
++de;
if (off == 1 && off < end) {
- eno = rtems_jffs2_fill_dirent(de, off, inode->i_parent->i_ino, "..");
+ eno = rtems_jffs2_fill_dirent(de, off, inode->i_parent->i_ino, "..", DT_DIR);
assert(eno == 0);
++off;
++de;
@@ -482,7 +485,7 @@ static ssize_t rtems_jffs2_dir_read(rtems_libio_t *iop, void *buf, size_t len)
while (eno == 0 && off < end && fd != NULL) {
if (fd->ino != 0) {
if (off == fd_off) {
- eno = rtems_jffs2_fill_dirent(de, off, fd->ino, fd->name);
+ eno = rtems_jffs2_fill_dirent(de, off, fd->ino, fd->name, fd->type);
++off;
++de;
diff --git a/cpukit/libfs/src/nfsclient/src/nfs.c b/cpukit/libfs/src/nfsclient/src/nfs.c
index ddb4dda313..bb338d58ca 100644
--- a/cpukit/libfs/src/nfsclient/src/nfs.c
+++ b/cpukit/libfs/src/nfsclient/src/nfs.c
@@ -327,6 +327,9 @@ nfscookie *pcookie;
pde->d_ino = fileid;
pde->d_namlen = nlen;
pde->d_off = di->ptr - di->buf;
+#ifdef DT_UNKNOWN
+ pde->d_type = DT_UNKNOWN;
+#endif
if (name == dummy.nambuf) {
memcpy(pde->d_name, dummy.nambuf, nlen + 1);
diff --git a/testsuites/fstests/fsscandir01/init.c b/testsuites/fstests/fsscandir01/init.c
index e92d2feceb..d7fb43c26b 100644
--- a/testsuites/fstests/fsscandir01/init.c
+++ b/testsuites/fstests/fsscandir01/init.c
@@ -8,47 +8,82 @@
#ifdef HAVE_CONFIG_H
- #include "config.h"
+#include "config.h"
#endif
-#include "fstest.h"
-#include "fs_config.h"
-#include "fstest_support.h"
-#include "pmacros.h"
+#include <sys/stat.h>
#include <dirent.h>
+#include <fcntl.h>
+#include <limits.h>
-#include <string.h>
#include <unistd.h>
-#include <errno.h>
-#include <limits.h>
+#include <tmacros.h>
+#include "fstest.h"
+#include "fs_config.h"
const char rtems_test_name[] = "FSSCANDIR " FILESYSTEM;
- * This code is from the scandir() man page.
-static void test_scandir(void)
+#define FILE_NAME "aaa"
+#define DIR_NAME "bbb"
+void test(void)
struct dirent **namelist;
+ struct dirent *d;
+ int rv;
int n;
+ int i;
+ rtems_test_assert(MAXNAMLEN == NAME_MAX);
+ rv = mknod(FILE_NAME, S_IFREG | S_IRWXU | S_IRWXG | S_IRWXO, 0);
+ rtems_test_assert(rv == 0);
+ rv = mkdir(DIR_NAME, S_IRWXU | S_IRWXG | S_IRWXO );
+ n = scandir(".", &namelist, NULL, alphasort);
+ rtems_test_assert(2 <= n || n == 4);
- n = scandir(".", &namelist, 0, NULL);
- if (n < 0) {
- perror("scandir");
- } else {
- while(n--) {
- printf("%s\n", namelist[n]->d_name);
- free(namelist[n]);
- free(namelist);
+ i = 0;
+ d = namelist[i];
+ if (n >= 3) {
+ rtems_test_assert(strcmp(d->d_name, ".") == 0);
+#ifdef DT_UNKNOWN
+ rtems_test_assert(d->d_type == DT_DIR || d->d_type == DT_UNKNOWN);
+#endif
+ free(d);
+ ++i;
+ d = namelist[i];
- rtems_test_assert(MAXNAMLEN == NAME_MAX);
+ if (n == 4) {
+ rtems_test_assert(strcmp(d->d_name, "..") == 0);
+#ifdef DT_UNKNOWN
+#endif
+ free(d);
+ ++i;
+ d = namelist[i];
+ rtems_test_assert(strcmp(d->d_name, FILE_NAME) == 0);
+#ifdef DT_UNKNOWN
+ rtems_test_assert(d->d_type == DT_REG || d->d_type == DT_UNKNOWN);
+#endif
+ free(d);
+ ++i;
+ d = namelist[i];
-void test (void)
- test_scandir();
+ rtems_test_assert(strcmp(d->d_name, DIR_NAME) == 0);
+#ifdef DT_UNKNOWN
+#endif
+ free(d);
+ free(namelist);
2.16.4
