[PATCH 1/6] Remove build date from first page
Mon Jan 7 13:43:52 UTC 2019
We need some indication for automated builds on RTEMS.org that the server
actually did build something. The script that builds the docs on the server
should create a file and put the build time in it.
On Mon, Jan 7, 2019, 5:04 AM Sebastian Huber <
sebastian.huber at embedded-brains.de wrote:
> The usage of a build date prevents reproducible builds.
>  common/conf.py | 25 +------------------------
>  1 file changed, 1 insertion(+), 24 deletions(-)
> diff --git a/common/conf.py b/common/conf.py
> index 60db066..8d5e6b8 100644
> --- a/common/conf.py
> +++ b/common/conf.py
> @@ -1,26 +1,3 @@
> -import datetime
> -def build_date():
> -    now = datetime.date.today()
> -    m = now.strftime('%B')
> -    y = now.strftime('%Y')
> -    if now.day == 11:
> -        s = 'th'
> -    elif now.day % 10 == 1:
> -        s = 'st'
> -    elif now.day == 12:
> -        s = 'th'
> -    elif now.day % 10 == 2:
> -        s = 'nd'
> -    elif now.day == 13:
> -        s = 'th'
> -    elif now.day == 3:
> -        s = 'rd'
> -    else:
> -        s = 'th'
> -    d = '%2d%s' % (now.day, s)
> -    return '%s %s %s' % (d, m, y)
>  extensions = [
>         "sphinx.ext.autodoc",
>         "sphinx.ext.coverage",
> @@ -47,7 +24,7 @@ master_doc = 'index'
>  # General information about the project.
>  project = u'RTEMS Documentation Project'
> -copyright = u'2018, RTEMS Project (built %s)' % (build_date())
> +copyright = u'2018, RTEMS Project'
>  # The version info for the project you're documenting, acts as
> replacement for
>  # |version| and |release|, also used in various other places throughout
> the
> 2.16.4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190107/664e00d4/attachment-0002.html>
