On 13/1/19 7:19 am, Vijay Kumar Banerjee wrote: > > With the recent change to the qemu options I'm getting results invalid when > running rtems-test without the coverage option. However, it works fine when the > coverage option is enabled. > What are the command lines for each run? Chris
