[PATCH] rtems-tools/covoar: -f switch was not used to select coverage format
Thu Jan 24 15:19:53 UTC 2019
On Thu, Jan 24, 2019 at 8:46 AM Jiri Gaisler <jiri at gaisler.se> wrote:
> On 1/24/19 2:19 PM, Joel Sherrill wrote:
> On Thu, Jan 24, 2019, 6:38 AM Jiri Gaisler <jiri at gaisler.se wrote:
>> Small patch to fix covoar to work with TSIM coverage files. It should be
>> noted that covoar erroneously marks some code as uncovered while it is
>> marked as covered in the coverage file. This seems to be due to incorrect
>> parsing of the symbol table in the exec file. I will file a ticket for this
>> on trac ..
> Is this the entry and exit code of a method or something else? The switch
> to dwarf info seems to have caused that and not marking assembly from
> inlined methods.
> I notice two problems: the first instruction in a range is sometimes
> marked as uncovered:
> 4000807c <_Freechain_Get>:
>   Freechain_Control   *freechain,
>   Freechain_Allocator  allocator,
>   size_t               number_nodes_to_extend,
>   size_t               node_size
> 4000807c:       9d e3 bf a0     save  %sp, -96, %sp
>                            <== NOT EXECUTED
> 40008080:       ba 10 00 18     mov  %i0, %i5
>   return _Chain_Immutable_head( the_chain )->next;
> 40008084:       f0 06 00 00     ld  [ %i0 ], %i0
> even though it is marked as executed in the coverage file. The second
> problems is that the size of ranges is sometimes off by one byte, e.g. 21
> bytes instead of 20. This can only be seen when debugging covoar in gdb.
I recall that the CoverageReaderTSIM code did an offset of +1 to +4 from
the address. Perhaps it just needs to be 0-3. :)
The off by one on the ranges is something else.
> I will prepare a patch for sis to add the coverage, and then covoar can be
> debugged using our standard tools. Maybe it could be a task for GSoC ...?
> An additional task could also be to add RISC-V support to covoar, which is
> currently missing...
Yes on GSoC. Use the keywords "SoC, testing" and it will show up in the
list here:
https://devel.rtems.org/wiki/Developer/OpenProjects
Clearly one bug isn't a GSoC project but if we file tickets for all the
issues, then that's a GSoC project.
RISC-V support would be awesome! I am thrilled you have added support for
it. :)
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190124/40e24d4f/attachment-0002.html>
