Zynq Runtime Socket Buffer Allocation Memory Reporting Question
Wed Jan 30 06:31:31 UTC 2019
Hello Avinash,
On 30/01/2019 02:08, Misra, Avinash wrote:
> Hi,
> I have a question in regards to changing the size of the socket
> buffers on the Zynq. It would appear that I can’t use the method
> described in Ch 4.3 of the Networking pdf since I don’t have the
> Ethernet driver and attach functions defined in the BSP.
the networking guide is for the legacy network stack. The libbsd has
some documentation here:
https://git.rtems.org/rtems-libbsd/tree/libbsd.txt
The network buffers are managed by UMA which uses a page allocator. The
memory area managed by the page allocator is determined during library
initialization. You can use the "vmstat -z" and "netstat -m" shell
commands to figure out something about the memory usage of libbsd.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
