[PATCH] misc/rtemsdefaultconfig: Add bdbuf so libbsd can be used with configure.
chrisj at rtems.org chrisj at rtems.org
Tue Jul 2 08:48:52 UTC 2019
 cpukit/libmisc/dummy/default-configuration.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/cpukit/libmisc/dummy/default-configuration.c b/cpukit/libmisc/dummy/default-configuration.c
index 629c58092b..5e130bce52 100644
--- a/cpukit/libmisc/dummy/default-configuration.c
+++ b/cpukit/libmisc/dummy/default-configuration.c
@@ -99,6 +99,8 @@ static void Init( rtems_task_argument arg )
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
 #define CONFIGURE_MAXIMUM_PROCESSORS CPU_MAXIMUM_PROCESSORS
 #define CONFIGURE_DISABLE_BSP_SETTINGS
@@ -106,4 +108,3 @@ static void Init( rtems_task_argument arg )
 #define CONFIGURE_INIT
 #include <rtems/confdefs.h>
2.20.1 (Apple Git-117)
