GSoC Project | Basic Support for Trace Compass
Tue Jul 2 10:10:50 UTC 2019
On 02/07/2019 12:03, Ravindra Kumar Meena wrote:
>      >     How many input file descriptors should this program use?
>      > I think it has to be equal to the value in defined
>      > variable RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT.
>     No, as I said before. You need exactly one input file. It is an
>     absolute
>     miracle to me, why you try to use multiple input files. It makes not
>     sense at all from my point of view.
> Okay. I have used only one file descriptor.
> https://github.com/rmeena840/rtems-tools/commit/a67decf3882db81970d88d3507763bf12627cbb6
Ok, good.
You open N output files. How many do you close?
Next step is to adjust the metadata so that it reflects the new event
stream format.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
