GSoC 2019 | POSIX Compliance - NDBM Port Successful. Minimal Testsuite working Successfully.
Fri Jul 5 16:50:19 UTC 2019
On Thu, Jul 4, 2019 at 2:31 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
> Hello,
> As I mentioned in previous threads, RSB patch was not generating function symbols defined
> in ndbm.c, but they were generated when I build newlib repository for SPARC.
> So, I made a script to add them manually, from newlib build, to rtems/5/.....
> https://github.com/VARoDeK/MiniProject_1-Add_newlib_object_files_to_rtems_libraries/blob/master/script.sh
> The compilation of minimal Testsuite was Successful this time and is generating
> expected correct results.
Good.
> OUTPUT
> *** BEGIN OF TEST PSXNDBM 01 ***
> *** TEST VERSION: 5.0.0.5cbee18e0030981cd61b8c9d556cc5c57f6ee082-modified
> *** TEST STATE: EXPECTED-PASS
> *** TEST BUILD: RTEMS_POSIX_API
> *** TEST TOOLS: 7.4.1 20190514 (RTEMS 5, RSB d694d16e5a7241827471af98c8f978ff3eb331fd, Newlib 5c2a3661c)
> Open Database
> Store Records in Database
> Fetch Records from Database
> Phone Number: 123-321-777-888
> Close Database
> *** END OF TEST PSXNDBM 01 ***
> *** FATAL ***
> fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
> fatal code: 0 (0x00000000)
> RTEMS version: 5.0.0.5cbee18e0030981cd61b8c9d556cc5c57f6ee082-modified
> RTEMS tools: 7.4.1 20190514 (RTEMS 5, RSB d694d16e5a7241827471af98c8f978ff3eb331fd, Newlib 5c2a3661c)
> executing thread ID: 0x08a010001
> executing thread name: UI1
> I will now make a Testsuite for each and every error and output.
> Should I send the ndbm patch to newlib now?
Did you post the final ndbm here already? if so, which was it? Your
mentors should take a good look before you will send it to newlib-ml
to avoid any obvious problems. (Or else, Joel might get scolded by
Corinna again. :))
> Patch for Testsuite
>  testsuites/psxtests/Makefile.am      |   8 +++
>  testsuites/psxtests/configure.ac     |   1 +
>  testsuites/psxtests/psxndbm01/init.c | 103 +++++++++++++++++++++++++++
>  3 files changed, 112 insertions(+)
>  create mode 100644 testsuites/psxtests/psxndbm01/init.c
> diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
> index 59c9f2085b..c805973afb 100755
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -694,6 +694,14 @@ psxmutexattr01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxmutexattr01) \
>   $(support_includes) -I$(top_srcdir)/include
>  endif
> +if TEST_psxndbm01
> +psx_tests += psxndbm01
> +psxndbm01_SOURCES = psxndbm01/init.c
> +psxndbm01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxndbm01) \
> +       $(support_includes)
> +endif
only need 1 blank line to separate things, like in the rest of this file.
>  if TEST_psxobj01
>  psx_tests += psxobj01
>  psx_screens += psxobj01/psxobj01.scn
> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
> index 85559e4aa5..07d7ccaf55 100644
> --- a/testsuites/psxtests/configure.ac
> +++ b/testsuites/psxtests/configure.ac
> @@ -110,6 +110,7 @@ RTEMS_TEST_CHECK([psxmsgq02])
>  RTEMS_TEST_CHECK([psxmsgq03])
>  RTEMS_TEST_CHECK([psxmsgq04])
>  RTEMS_TEST_CHECK([psxmutexattr01])
> +RTEMS_TEST_CHECK([psxndbm01])
>  RTEMS_TEST_CHECK([psxobj01])
>  RTEMS_TEST_CHECK([psxonce01])
>  RTEMS_TEST_CHECK([psxpasswd01])
> diff --git a/testsuites/psxtests/psxndbm01/init.c b/testsuites/psxtests/psxndbm01/init.c
> new file mode 100644
> index 0000000000..74dec0c969
> --- /dev/null
> +++ b/testsuites/psxtests/psxndbm01/init.c
> @@ -0,0 +1,103 @@
> + *  @file
> + *  @brief Test suite for inttypes.h methods
inttypes.h?
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2019 Vaibhav Gupta
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <errno.h>
> +#include <fcntl.h>
> +#include <ndbm.h>
> +#include <stddef.h>
> +#include <stdint.h>
> +#include <stdio.h>
> +#include <sys/stat.h>
> +#include <rtems/test.h>
> +#include <tmacros.h>
Only need one blank line to separate things.
> +const char rtems_test_name[] = "PSXNDBM 01";
> +#define NAME     "VARoDeK"
> +#define PHONE_NO "123-321-777-888"
> +#define DB_NAME  "phones_test"
> +/* forward declarations to avoid warnings */
> +rtems_task Init(rtems_task_argument ignored);
> +DBM *db;
> +  datum name = { NAME , sizeof(NAME) };
> +  datum put_phone_no = { PHONE_NO, sizeof(PHONE_NO) };
> +  datum get_phone_no;
> +  TEST_BEGIN();
> +  puts( "Open Database" );
> +  db = dbm_open( DB_NAME , O_RDWR | O_CREAT | O_TRUNC , S_IRWXU );
> +  rtems_test_assert( db != NULL );
> +  puts( "Store Records in Database" );
> +  dbm_store( db , name , put_phone_no , DBM_INSERT );
Can you check this call for any return value / errors?
> +  puts( "Fetch Records from Database" );
> +  get_phone_no = dbm_fetch( db , name );
> +  printf( "\nName: %s, \nPhone Number: %s\n\n", (char *)name.dptr , (char *)get_phone_no.dptr );
How do you determine the test is successful?  You must manually view
the output?  Can you make this test to fail in case the dbm_fetch is
wrong?
> +  puts( "Close Database" );
> +  dbm_close( db );
1 blank line only
> +  TEST_END();
> +  rtems_test_exit(0);
> +/* NOTICE: the clock driver is explicitly disabled */
> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_MAXIMUM_TASKS            1
> +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 6
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#include <rtems/confdefs.h>
> +/* end of file */
> 2.21.0
