[PATCH] RTEMS 5 3rd party packages
chrisj at rtems.org chrisj at rtems.org
Sat Jul 6 09:30:21 UTC 2019
Hi
This patch updates all 3rd party packages the RSB has for RTEMS. Not all packages are
building and I have not had the time to get them working. Any help would be welcome.
- NTP
  The error is someting about not supporting a 64bit time_t. Maybe the dev verison
  will work.
- Net-NSMP
  This does not build with LibBSD. It is a lot of work to get this to build due
  to issues between function decls in the FreeBSD kernel and our libc, It can
  be made to build but I think clear support for RTEMS would be needed.
- Microwindows
  There is no tarball download any more and it has moved to git. The patches
  do not apply and this package has a special Makefile.
- Some packages are using Makefile.inc and these should be changed to
  using the defined flags that are extracted from the BSP's pkgconfig
  file.
- Addition of 5/rtems-packages for all packages that build.
- Added libcurl tp the packages.
