Easy Approach to Requirements Syntax?
Mon Jul 8 06:42:51 UTC 2019
Hello,
I work currently on a requirements engineering section for RTEMS in the
RTEMS Software Engineering manual:
https://docs.rtems.org/branches/master/eng/index.html
There should be some recommendations on how to formulate requirements.
What do you thing about the: Easy Approach to Requirements Syntax
(EARS)? Has someone used this before? Is it something to recommend?
https://www.researchgate.net/publication/224079416_Easy_approach_to_requirements_syntax_EARS
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
