Easy Approach to Requirements Syntax?
Tue Jul 9 05:34:45 UTC 2019
On 08/07/2019 08:42, Sebastian Huber wrote:
> Hello,
> I work currently on a requirements engineering section for RTEMS in the
> RTEMS Software Engineering manual:
> https://docs.rtems.org/branches/master/eng/index.html
> There should be some recommendations on how to formulate requirements.
> What do you thing about the: Easy Approach to Requirements Syntax
> (EARS)? Has someone used this before? Is it something to recommend?
> https://www.researchgate.net/publication/224079416_Easy_approach_to_requirements_syntax_EARS
Just for reference, there is also a follow-up paper:
https://www.researchgate.net/publication/224195362_Big_Ears_The_Return_of_Easy_Approach_to_Requirements_Engineering
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
