[PATCH v4] Port ndbm
Aditya Upadhyay
aadit0402 at gmail.com
Wed Jul 10 03:23:55 UTC 2019
On Tue, Jul 9, 2019, 11:49 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> newlib/libc/include/ndbm.h | 91 ++++++++++++++
> newlib/libc/search/Makefile.am | 1 +
> newlib/libc/search/ndbm.c | 220 +++++++++++++++++++++++++++++++++
> 3 files changed, 312 insertions(+)
> create mode 100644 newlib/libc/include/ndbm.h
> create mode 100644 newlib/libc/search/ndbm.c
> diff --git a/newlib/libc/include/ndbm.h b/newlib/libc/include/ndbm.h
> new file mode 100644
> index 000000000..6761d4897
> --- /dev/null
> +++ b/newlib/libc/include/ndbm.h
> @@ -0,0 +1,91 @@
> + * SPDX-License-Identifier: BSD-3-Clause
> + * Copyright (c) 1990, 1993
> + * The Regents of the University of California. All rights reserved.
> + * This code is derived from software contributed to Berkeley by
> + * Margo Seltzer.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * 3. Neither the name of the University nor the names of its contributors
> + * may be used to endorse or promote products derived from this
> software
> + * without specific prior written permission.
> + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE
> LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
> STRICT
> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY
> WAY
> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> + * SUCH DAMAGE.
> + * @(#)ndbm.h 8.1 (Berkeley) 6/2/93
> + * $FreeBSD$
> +#ifndef _NDBM_H_
> +#define _NDBM_H_
> +/* #include <db.h> */
> +* The above header-file is directly included in
> `newlib/libc/search/ndbm.c`
> +* as `db.h` is present in form of `db_local.h`, that too inside
> +* `newlib/libc/search` directory and not in `newlib/libc/include`.
> +* Necessary data-types are mentioned in form of forward-declarations
> +/* Map dbm interface onto db(3). */
> +#define DBM_RDONLY O_RDONLY
> +/* Flags to dbm_store(). */
> +#define DBM_INSERT 0
> +#define DBM_REPLACE 1
> + * The db(3) support for ndbm always appends this suffix to the
> + * file name to avoid overwriting the user's original database.
> +#define DBM_SUFFIX ".db"
> +typedef struct {
> + void *dptr;
> + int dsize; /* XXX Should be size_t according to 1003.1-2008.
> +} datum;
> +struct __db; /* Forward-declaration */
> +typedef struct __db DB; /* Forward-declaration */
> +typedef DB DBM;
> +#define dbm_pagfno(a) DBM_PAGFNO_NOT_AVAILABLE
> +__BEGIN_DECLS
> +int dbm_clearerr(DBM *);
> +void dbm_close(DBM *);
> +int dbm_delete(DBM *, datum);
> +int dbm_error(DBM *);
> +datum dbm_fetch(DBM *, datum);
> +datum dbm_firstkey(DBM *);
> +#if __BSD_VISIBLE
> +long dbm_forder(DBM *, datum);
> +#endif
> +datum dbm_nextkey(DBM *);
> +DBM *dbm_open(const char *, int, mode_t);
> +int dbm_store(DBM *, datum, datum, int);
> +#if __BSD_VISIBLE
> +int dbm_dirfno(DBM *);
> +#endif
> +__END_DECLS
> +#endif /* !_NDBM_H_ */
> diff --git a/newlib/libc/search/Makefile.am
> b/newlib/libc/search/Makefile.am
> index 98920c3f4..a61107fb9 100644
> --- a/newlib/libc/search/Makefile.am
> +++ b/newlib/libc/search/Makefile.am
> @@ -9,6 +9,7 @@ GENERAL_SOURCES = \
> db_local.h \
> extern.h \
> hash.h \
> + ndbm.c \
> page.h \
> qsort.c
> diff --git a/newlib/libc/search/ndbm.c b/newlib/libc/search/ndbm.c
> index 000000000..7226be1d1
> --- /dev/null
> +++ b/newlib/libc/search/ndbm.c
> @@ -0,0 +1,220 @@
> + * Margo Seltzer.
> + * are met:
> software
> PURPOSE
> LIABLE
> CONSEQUENTIAL
> STRICT
> WAY
> + * SUCH DAMAGE.
> +#if defined(LIBC_SCCS) && !defined(lint)
> +static char sccsid[] = "@(#)ndbm.c 8.4 (Berkeley) 7/21/94";
> +#endif /* LIBC_SCCS and not lint */
> +#include <sys/cdefs.h>
> +__FBSDID("$FreeBSD$ : src/lib/libc/db/hash/ndbm.c Nov 20 19:49:47 2017
> UTC by pfg");
> + * This package provides a dbm compatible interface to the new hashing
> + * package described in db(3).
> +#include <sys/param.h>
> +#include <stdio.h>
> +#include <string.h>
> +#include <errno.h>
> +#include <ndbm.h>
> +#include "hash.h"
> +#ifndef __DBINTERFACE_PRIVATE
> +#define __DBINTERFACE_PRIVATE
> +#endif
Here you do not have dbinterface_private.h.
You are accessing db_local private prototypes. So for this guard #define
__DBINTERFACE_PRIVATE, You will have to specify db_local.h.
See this example:
https://github.com/mirror/newlib-cygwin/blob/bd993df0e6aee5080a791b54cb0074ad76bab681/newlib/libc/search/hash.c
+#include "db_local.h"
> + * Returns:
> + * *DBM on success
> + * NULL on failure
> +extern DBM *
> +dbm_open(const char *file, int flags, mode_t mode)
> + HASHINFO info;
> + char path[MAXPATHLEN];
> + info.bsize = 4096;
> + info.ffactor = 40;
> + info.nelem = 1;
> + info.cachesize = 0;
> + info.hash = NULL;
> + info.lorder = 0;
> + if( strlen(file) >= sizeof(path) - strlen(DBM_SUFFIX)) {
> + errno = ENAMETOOLONG;
> + return(NULL);
> + (void)strcpy(path, file);
> + (void)strcat(path, DBM_SUFFIX);
> + return ((DBM *)__hash_open(path, flags, mode, 0, &info));
> +extern void
> +dbm_close(DBM *db)
> + (void)(db->close)(db);
> + * Returns:
> + * DATUM on success
> + * NULL on failure
> +extern datum
> +dbm_fetch(DBM *db, datum key)
> + datum retdata;
> + int status;
> + DBT dbtkey, dbtretdata;
> + dbtkey.data = key.dptr;
> + dbtkey.size = key.dsize;
> + status = (db->get)(db, &dbtkey, &dbtretdata, 0);
> + if (status) {
> + dbtretdata.data = NULL;
> + dbtretdata.size = 0;
> + retdata.dptr = dbtretdata.data;
> + retdata.dsize = dbtretdata.size;
> + return (retdata);
> + * Returns:
> + * NULL on failure
> +extern datum
> +dbm_firstkey(DBM *db)
> + int status;
> + datum retkey;
> + DBT dbtretkey, dbtretdata;
> + status = (db->seq)(db, &dbtretkey, &dbtretdata, R_FIRST);
> + if (status)
> + dbtretkey.data = NULL;
> + retkey.dptr = dbtretkey.data;
> + retkey.dsize = dbtretkey.size;
> + return (retkey);
> + * Returns:
> + * NULL on failure
> +extern datum
> +dbm_nextkey(DBM *db)
> + int status;
> + datum retkey;
> + status = (db->seq)(db, &dbtretkey, &dbtretdata, R_NEXT);
> + if (status)
> + return (retkey);
> + * Returns:
> + * 0 on success
> + * <0 failure
> +extern int
> +dbm_delete(DBM *db, datum key)
> + int status;
> + DBT dbtkey;
> + status = (db->del)(db, &dbtkey, 0);
> + if (status)
> + return (-1);
> + else
> + return (0);
> + * Returns:
> + * 0 on success
> + * <0 failure
> + * 1 if DBM_INSERT and entry exists
> +extern int
> +dbm_store(DBM *db, datum key, datum data, int flags)
> + DBT dbtkey, dbtdata;
> + dbtdata.data = data.dptr;
> + dbtdata.size = data.dsize;
> + return ((db->put)(db, &dbtkey, &dbtdata,
> + (flags == DBM_INSERT) ? R_NOOVERWRITE : 0));
> +extern int
> +dbm_error(DBM *db)
> + HTAB *hp;
> + hp = (HTAB *)db->internal;
> + return (hp->error);
> +extern int
> +dbm_clearerr(DBM *db)
> + HTAB *hp;
> + hp->error = 0;
> + return (0);
> +extern int
> +dbm_dirfno(DBM *db)
> + return(((HTAB *)db->internal)->fp);
Just make this change and send a fresh patch to newlib mailing list and
also specify the freebsd source of ndbm.h and ndbm.c in a patch format
separately from the your ndbm patch.
2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190710/f37e1583/attachment-0001.html>
