[PATCH v3] ndbm test suite
Vaibhav Gupta vaibhavgupta40 at gmail.com
Wed Jul 10 04:43:13 UTC 2019
On Wed, Jul 10, 2019, 9:24 AM Aditya Upadhyay <aadit0402 at gmail.com> wrote:
> You should also add these two files:  .scn file and .doc file.
> On Tue, Jul 9, 2019, 5:48 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>>  testsuites/psxtests/Makefile.am      |   7 +
>>  testsuites/psxtests/configure.ac     |   1 +
>>  testsuites/psxtests/psxndbm01/init.c | 251 +++++++++++++++++++++++++++
>>  3 files changed, 259 insertions(+)
>>  create mode 100644 testsuites/psxtests/psxndbm01/init.c
>> diff --git a/testsuites/psxtests/Makefile.am
>> b/testsuites/psxtests/Makefile.am
>> index 59c9f2085b..7d1c0a783c 100755
>> --- a/testsuites/psxtests/Makefile.am
>> +++ b/testsuites/psxtests/Makefile.am
>> @@ -694,6 +694,13 @@ psxmutexattr01_CPPFLAGS = $(AM_CPPFLAGS)
>> $(TEST_FLAGS_psxmutexattr01) \
>>         $(support_includes) -I$(top_srcdir)/include
>>  endif
>> +if TEST_psxndbm01
>> +psx_tests += psxndbm01
>> +psxndbm01_SOURCES = psxndbm01/init.c
> Same here. Add .scn and .doc files.
Yah .doc and .scn i was planning, after this init.c gets finalized.
> +psxndbm01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxndbm01) \
>> +       $(support_includes)
>> +endif
>>  if TEST_psxobj01
>>  psx_tests += psxobj01
>>  psx_screens += psxobj01/psxobj01.scn
>> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
>> configure.ac
>> index 85559e4aa5..07d7ccaf55 100644
>> --- a/testsuites/psxtests/configure.ac
>> +++ b/testsuites/psxtests/configure.ac
>> @@ -110,6 +110,7 @@ RTEMS_TEST_CHECK([psxmsgq02])
>>  RTEMS_TEST_CHECK([psxmsgq03])
>>  RTEMS_TEST_CHECK([psxmsgq04])
>>  RTEMS_TEST_CHECK([psxmutexattr01])
>> +RTEMS_TEST_CHECK([psxndbm01])
>>  RTEMS_TEST_CHECK([psxobj01])
>>  RTEMS_TEST_CHECK([psxonce01])
>>  RTEMS_TEST_CHECK([psxpasswd01])
>> diff --git a/testsuites/psxtests/psxndbm01/init.c
>> b/testsuites/psxtests/psxndbm01/init.c
>> new file mode 100644
>> index 0000000000..eacbf0d983
>> --- /dev/null
>> +++ b/testsuites/psxtests/psxndbm01/init.c
>> @@ -0,0 +1,251 @@
>> + *  @file
>> + *  @brief Test suite for ndbm.h methods
>> + * SPDX-License-Identifier: BSD-2-Clause
>> + * Copyright (C) 2019 Vaibhav Gupta
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + *    notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + *    notice, this list of conditions and the following disclaimer in the
>> + *    documentation and/or other materials provided with the
>> distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>> "AS IS"
>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>> THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
>> BE
>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> BUSINESS
>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
>> IN
>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>> OTHERWISE)
>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>> OF THE
>> + * POSSIBILITY OF SUCH DAMAGE.
>> +#ifdef HAVE_CONFIG_H
>> +#include "config.h"
>> +#endif
>> +/* header files are listed in lexical/lexicographical/alphabetical order
>> +#include <errno.h>
>> +#include <fcntl.h>      /* contains definitions of `open_flags` */
>> +#include <limits.h>
>> +#include <ndbm.h>       /* conatains declarations of ndbm methods */
>> +#include <stddef.h>
>> +#include <stdint.h>
>> +#include <stdio.h>
>> +#include <sys/stat.h>   /* contains definitions of `file_mode` */
>> +#include <string.h>
>> +#include <rtems/test.h>
>> +#include <tmacros.h>
>> +const char rtems_test_name[] = "PSXNDBM 01";
>> +#define NAME      "VARoDeK"
>> +#define PHONE_NO  "123-321-777-888"
>> +#define DB_NAME   "phones_test"
>> +#define NAME2     "VG"
>> +#define PHONE_NO2 "321-123-888-777"
>> +/* forward declarations to avoid warnings */
>> +rtems_task Init(rtems_task_argument ignored);
>> +  datum name = { NAME , sizeof( NAME ) };
>> +  datum put_phone_no = { PHONE_NO, sizeof( PHONE_NO ) };
>> +  datum get_phone_no, key;
>> +  datum name2 = { NAME2 , sizeof( NAME2 ) };
>> +  datum put_phone_no2 = { PHONE_NO2 , sizeof( PHONE_NO2 ) };
>> +  int i;
>> +  char *test_strings;
>> +  DBM *db;
>> +  TEST_BEGIN();
>> +  /* A Simple test to check if ndbm methods are call-able */
>> +  /* Store a simple data */
>> +  puts( "Open Database." );
>> +  db = dbm_open( DB_NAME , O_RDWR | O_CREAT | O_TRUNC , S_IRWXU );
>> +  rtems_test_assert( db != NULL );
>> +  puts( "Store Records in Database." );
>> +  dbm_store( db , name , put_phone_no , DBM_INSERT );
>> +  puts( "Fetch Records from Database and check." );
>> +  get_phone_no = dbm_fetch( db , name );
>> +  rtems_test_assert( strcmp( (const char*)get_phone_no.dptr , PHONE_NO )
>> == 0 );
> If dbm_fetch function fails, in that case, it should set dptr value of
> datum structure to NULL. Are you checking that value?
Yes this i am checking.
> Add some failure cases also like if we provide some wrong name, dptr
> should set to NULL and it should also return respective error number.
This I have done. Providing wrong key.  Its below.
> +  puts( "Close Database." );
>> +  dbm_close( db );
>> +  /* dbm_open() */
>> +  puts( "\nTestcases for `dbm_open()`" );
>> +  /* The `DB_NAME` is already created, hence `O_RDWR | O_EXCL` should
>> fail. */
>> +  puts( "Use `O_CREAT | O_EXCL` to open existing file and confirm
>> error." );
>> +  db = dbm_open( DB_NAME , O_RDWR | O_CREAT | O_EXCL , S_IRWXU );
>> +  rtems_test_assert( db == NULL );
>> +  rtems_test_assert( errno == EEXIST );
>> +  /* Some implementations use 3 characters for a suffix and others use
>> +  * 4 characters for a suffix, applications should ensure that the
>> maximum
>> +  * portable pathname length passed to dbm_open() is no greater than
>> +  * {PATH_MAX}-4 bytes, with the last component of the pathname no
>> greater
>> +  * than {NAME_MAX}-4 bytes.
>> +  /* inside `ndbm.h` ; `#define        DBM_SUFFIX      ".db"` ;
>> +  * 2 alphabtes and 1 period, hence 3 characters are used for suffix
>> +  * in this implementation.
>> +  puts( "Use path name larger than `{PATH_MAX}-3 bytes.` and confirm
>> error." );
>> +  test_strings = (char*)malloc( ( PATH_MAX - 2 ) );
>> +  for ( i = 0 ; i < ( PATH_MAX - 3 ) ; i++ ){
>> +    test_strings[i] = 'r';
>> +  test_strings[i] = '\0';
>> +  db = dbm_open( (const char*)test_strings , O_RDWR | O_CREAT | O_TRUNC
>> , S_IRWXU );
>> +  rtems_test_assert( errno == ENAMETOOLONG );
>> +  free( test_strings );
>> +  /* database opened for write-only access opens the files for read and
>> +  * write access or it will fail.
>> +  /* Implemenation of __hash_open in newlib does not support `O_WRONLY`
>> +  puts( "Open file with write access only and confirm error." );
>> +  db = dbm_open( DB_NAME , O_WRONLY , S_IRWXU );
>> +  rtems_test_assert( errno == EINVAL );
>> +  /* dbm_store() */
>> +  puts( "\nTestcases for `dbm_store()`" );
>> +  db = dbm_open( DB_NAME , O_RDWR , S_IRWXU );
>> +  puts( "Insert new record with same key using `DBM_INSERT` mode and
>> confirm error." );
>> +  rtems_test_assert( dbm_store( db , name , put_phone_no2 , DBM_INSERT )
>> == 1 );
>> == 0 );
>> +  puts( "Insert new record with same key using `DBM_REPLACE` mode and
>> confirm changes." );
>> +  rtems_test_assert( dbm_store( db , name , put_phone_no2 , DBM_REPLACE
>> ) == 0 );
>> +  rtems_test_assert( strcmp( (const char*)get_phone_no.dptr , PHONE_NO2
>> ) == 0 );
>> +  /* Revert for next tests*/
>> +  rtems_test_assert( dbm_store( db , name , put_phone_no , DBM_REPLACE )
>> == 0 );
>> +  puts( "Store a new record and confirm, total number of records is
>> successful 2." );
>> +  rtems_test_assert( dbm_store( db , name2 , put_phone_no2 , DBM_INSERT
>> ) == 0 );
>> +  for(key = dbm_firstkey( db ) , i = 0; key.dptr != NULL; key =
>> dbm_nextkey( db ) , i++ );
>> +  rtems_test_assert( i == 2);
>> +  dbm_close( db );
>> +  /* dbm_fetch() */
>> +  puts( "\nTestcases for `dbm_fetch()`" );
>> +  db = dbm_open( DB_NAME , O_RDONLY , S_IRWXU );
>> +  puts( "Fetch existing records and confirm results." );
>> == 0 );
>> +  get_phone_no = dbm_fetch( db , name2 );
>> ) == 0 );
>> +  puts( "Fetch non-existing record and conform error." );
>> +  test_strings = (char*)malloc(6);
>> +  strcpy( test_strings , "Hello" );
>> +  key.dptr = test_strings;
>> +  key.dsize = sizeof( test_strings );
>> +  get_phone_no = dbm_fetch( db , key );
>> +  rtems_test_assert( get_phone_no.dptr == NULL );
> Like here, I have checked the NULL value of dptr.
> +  dbm_close( db );
>> +  /* dbm_delete() */
>> +  puts( "\nTestcases for `dbm_delete()`" );
>> +  puts( "Delte non-existing record and confirm error." );
>> +  rtems_test_assert( dbm_delete( db , key ) != 0 );
>> +  puts("Delete existing record and confirm, total number of records is
>> successful 1.");
>> +  rtems_test_assert( dbm_delete( db , name ) == 0 );
>> +  rtems_test_assert( i == 1);
>> +  puts("Confirm if correct record is deleted.");
>> +  /* record returned by `dbm_firstkey()` should be the only record
>> +  * left, this should be checked to confirm correct working of
>> +  * `dbm_firstkey()`.
>> +  * Check if the data is not corrupted after usage of `dbm_delete()`
>> +  puts( "Check if the data is not corrupted after usage of
>> `dbm_delete()`." );
>> +  get_phone_no = dbm_fetch( db , dbm_firstkey( db ) );
>> ) == 0 );
>> +  /* Empty the database and then try to use `dbm_firstkey()`, the
>> +  * dptr pointer should point to NULL.
>> +  puts( "Empty records in database and check results of
>> `dbm_firstkey()`." );
>> +  rtems_test_assert( dbm_delete( db , dbm_firstkey( db ) ) == 0 );
>> +  key = dbm_firstkey( db );
>> +  rtems_test_assert( key.dptr == NULL );
>> +  dbm_close( db );
>> +  /* `dbm_firstkey()` */
>> +  puts( "\nTestcases for `dbm_firstkey()`" );
>> +  puts( "All cases tested while performing above tests." );
>> +  /* `dbm_nextkey()` */
>> +  puts( "\nTestcases for `dbm_nextkey()`" );
>> +  TEST_END();
>> +  rtems_test_exit(0);
>> +/* NOTICE: the clock driver is explicitly disabled */
>> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> +#define CONFIGURE_MAXIMUM_TASKS                  1
>> +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 6
>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>> +#include <rtems/confdefs.h>
>> +/* end of file */
>> \ No newline at end of file
>> 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190710/2e939985/attachment-0001.html>
