GSoC Project | Basic support for Trace Compass
Ravindra Kumar Meena
rmeena840 at gmail.com
Thu Jul 11 05:00:26 UTC 2019
> This is not a proper argument. You should use the packet context to
> indicate the CPU of the events.
I have added the ctf_header in rtems_main.c
https://github.com/rmeena840/rtems-tools/commit/5a1c7b6e3c0c5246a8afc538f9f01576a5ac7983
Tested on AWS. No warning from my end.
Now, each binary stream file has format:
<stream_id=0> <cpu_id> <ns> <event> <data> <ns> <event> <data> ........
I have stream_id = 0 because in metadata there is one stream with id=0 so
it has to be there.
Both stream_id and cpu_id is playing the role of header.
Here the modified metadata:
https://github.com/rmeena840/rtems-tools/commit/afc73eb33c4366d81d63330f35e03af5df1410f5
The metadata has the same format as described above.
Babeltrace is able to read values. Here is the output:
0 RTEMS_RECORDING_EVENT: { cpu_id = 4 }, { ns = 954631069457, events = (
"RTEMS_RECORD_THREAD_STACK_CURRENT" : container = 209 ), data =
134621454958589 }
0 RTEMS_RECORDING_EVENT: { cpu_id = 18 }, { ns = 955492534605, events = (
"RTEMS_RECORD_THREAD_SWITCH_OUT" : container = 216 ), data =
720857707413798909 }
0 RTEMS_RECORDING_EVENT: { cpu_id = 19 }, { ns = 955499514125, events = (
"RTEMS_RECORD_THREAD_SWITCH_IN" : container = 215 ), data =
648799898627506173 }
As you can see. It now includes cpu_id also.
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190711/b1b47f0c/attachment.html>
