GSoC 2019 | POSIX Compliance - RSB patch generated ndbm library (lib_a-ndbm.o) successfully in RTEMS Toolchain
Vaibhav Gupta vaibhavgupta40 at gmail.com
Thu Jul 11 07:11:50 UTC 2019
Hello,
After Joel pointed out in an offlist discussion,
I made a new patch for ndbm port.
To send the changes to Newlib, i had to place `ndbm.h` , `ndbm.c` in their
respective places and make  changes in Makefile.am.
Before, I applied same patch to RSB hence ndbm library was not generated.
This time I also added files generated by `autoreconf -fvi` in the patch.
This patch is 10MB in size hence cannot be send in raw format on mailing
list.
This patch worked with RSB and ndbm library (lib_a-ndbm.o) was generated
successfully in RTEMS Toolchain.
Thank you
Vaibhav Gupta
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190711/2d228c1d/attachment.html>
