Requirement Identifiers
Sebastian Huber
Thu Jul 11 08:15:41 UTC 2019
Hello,
I work currently on a requirements engineering section for RTEMS in the
RTEMS Software Engineering manual:
https://docs.rtems.org/branches/master/eng/index.html
The goal is to add a technical specification for a subset of RTEMS. A
technical specification consists of requirements. One basic element is
that requirements can be identified. We have to discuss how requirements
are identified in the RTEMS project.
The proposed tool to manage requirements in RTEMS is Doorstop:
https://github.com/jacebrowning/doorstop
This tool add some restrictions to the way requirements are identified.
The following text is a part of my requirements engineering draft
document in ReST format.
Identification
Each requirement shall have a unique identifier (UID). The open
question is in
which scope should it be unique? Ideally, it should be universally
unique. As
a best effort approach, the name *RTEMS* shall be used as a part in all
requirement identifiers. This should ensure that the RTEMS requirements
can be
referenced easily in larger systems. The standard ECSS-E-ST-10-06C
recommends
in section 8.2.6 that the identifier should reflect the type of the
requirement
and the life profile situation. Other standards may have other
recommendations. To avoid a bias of RTEMS in the direction of ECSS, this
recommendation will not be followed. In addition, it would also make
the use
of :term:`Doorstop` more difficult, since this tool does not support
attribute
dependent identifiers.
.. topic:: Doorstop
The UID of an item (requirement) is defined by its file name
without the
extension. An UID consists of two parts, the prefix and a number.
The parts
are divided by an optional separator. The prefix is determined by the
document to which the item belongs.
Proposal: Default Doorstop Numbering
One UID scheme for RTEMS requirements is the concatenation of *RTEMS* and a
5-digit number which is automatically generated by Doorstop. It starts with
RTEMS00001 and ends with RTEMS99999. These identifiers are just unique and
bear no other information.
Proposal: Number Groups
Another UID scheme for RTEMS requirements is the concatenation of
*RTEMS* and a
5-digit number which reflects the hierarchy of requirements. For
example UIDs
from RTEMS01000 to RTEMS01999 are task requirements, UIDs from RTEMS02000 to
RTEMS02999 are semaphore requirements, UIDs from RTEMS03000 to
RTEMS03999 are
message queue requirements, etc. It would be also possible to add a
separator
character, for example RTEMS-01234.
.. topic:: Doorstop
This is currently not supported by Doorstop, see `issue #349
<https://github.com/jacebrowning/doorstop/issues/349>`_.
Proposal: Document Hierarchy
*RTEMS*, one
or more component names, and a 3-digit number which reflects the
hierarchy of
requirements. Each part is separated by a "-" character. For example UIDs
from RTEMS-Classic-Task-001 to RTEMS-Classic-Task-999 are task requirements,
UIDs from RTEMS-Classic-Semaphore-001 to RTEMS-Classic-Semaphore-999 are
semaphore requirements, UIDs from RTEMS-Classic-MQ-001 to
RTEMS-Classic-MQ-999
are message queue requirements, etc. The benefit is that requirement
files are
organized in directories.
.. topic:: Doorstop
Doorstop uses documents to create namespaces (named a prefix in
Doorstop).
For the example above, you can create the documents like this:
.. code-block:: none
doorstop create -d 3 RTEMS-Classic -p RTEMS reqs/classic
doorstop create -d 3 RTEMS-Classic-Task -p RTEMS-Classic
reqs/classic/task
doorstop create -d 3 RTEMS-Classic-Semaphore -p RTEMS-Classic
reqs/classic/semaphore
doorstop create -d 3 RTEMS-Classic-MQ -p RTEMS-Classic
reqs/classic/mq
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
