Build failed for RTEMS Source Builder
Fri Jul 12 01:24:52 UTC 2019
On 12/7/19 7:26 am, Himanshu Sekhar Nayak wrote:
> Hello guys,
> I am trying to setup the rtems source builder from this
> linkhttps://docs.rtems.org/branches/master/user/overview/index.html
> <https://docs.rtems.org/branches/master/user/overview/index.html> but build is
> failing due to autoconf. I have also gone through pre-requirments that need for
> the setup to build but seems like autoconf is failing it. Btw I am testing under
> MX Linux which is also a debian based distro. Any idea ?
> here is the error report https://paste.ofcode.org/37fg9TKr2q77Thwh5j8Yqxf
I do not understand why sed is set to
/home/himanshu/quick-start/rtems/5/usr/bin/sed. The error report is saying it
has been found at /usr/bin/sed.
I suggest running with `--trace` and inspecting the log to see if this helps
explain why it is getting confused.
