GSoC Linux UIO driver for PRU
Joel Sherrill
joel at rtems.org
Sat Jul 13 23:34:46 UTC 2019
On Sat, Jul 13, 2019 at 1:42 PM Chris Johns <chrisj at rtems.org> wrote:
> On 13/7/19 5:16 pm, Nils Hölscher wrote:
> > Hi,
> > After I made sure that my fdt is correct I wondered why the pruss was
> still not
> > accessible.
> > When I researched more about userspace drivers in Linux I found out,
> that I have
> > overseen the pru UIO module in Linux.
> > This is the part that links the PRUs to the /dev/uio[0-7].
> > Which then would be used by the sources I currently use.
> > The UIO source is available here:
> > https://github.com/beagleboard/linux/blob/3.8/drivers/uio/uio_pruss.c
> > However this requires the linux UIO lib to load the modules and abstract
> the
> > device into a file.
> > While researching I also found that BSD has a PRU driver.
> > Also this driver is more feature rich as it support PRU debugging.
> > The sources can be found her:
> > https://bitbucket.org/rpaulo/libpru/src/default/
> > Additionally I found these sources in the FreeBSD tree:
> https://github.com/freebsd/freebsd/blob/250e158ddf52459661439141407bca505d199c19/sys/arm/ti/ti_pruss.c
> > This code also registers the PRUs in /dev/.
> > On the other hand the BSD drivers have no documentation at all.
> > These are the code lines that will fail without a file in /dev.
> > Linux:
> https://github.com/nilhoel1/rtems-pru/blob/master/ti/prussdrv.c#L265
> > BSD:
> https://bitbucket.org/rpaulo/libpru/src/5cb7271533a96d177e73492f7cc40fa4b28396a5/ti-pru.c#lines-614
> > So my questions are:
> > 1. How are drivers registered to /dev in RTEMS? (examples)
> I suggest you look at cpukit/include/rtems/io.h and then for examples of
> this
> interface being used in the bsp directory.
There is a helper in the IO Manager which is implemented as a call to
mknod()
which is a standard call.
> > 2. Which driver would be a better starting point to bring pruss support
> to RTEMS?
> The bitbucket set of drivers look pretty good so I think just use them and
> add
> to the beagle bsp.
+1 If needed,
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190713/87af2fd5/attachment.html>
