Build failed for RTEMS Source Builder
Mon Jul 15 16:45:17 UTC 2019
On Sun, Jul 14, 2019 at 4:36 PM Chris Johns <chrisj at rtems.org> wrote:
> On 15/7/19 4:09 am, Himanshu Sekhar Nayak wrote:
> > Looks RTEMS Source builder is finding the path in /bin instead of /usr/bin in MX
> > Linux. Does it vary from distro to distro ?
> It varies between operating systems. I am not sure about Linux, I do not spend a
> lot of time using it.
Probably it depends on the order of your $PATH. Usually, we should see
/usr/bin in $PATH before /bin, since it is preferred to pick up the
user's version of executables before the system's. I would guess MX
has done it backward for some reason.
> Chris
> devel mailing list
> devel at rtems.org
