GSoC 2019 | POSIX Compliance - RSB patch generated ndbm library (lib_a-ndbm.o) successfully in RTEMS Toolchain
Mon Jul 15 16:51:20 UTC 2019
On Thu, Jul 11, 2019 at 9:01 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
> Sounds good to me.
> On Thu, Jul 11, 2019 at 6:47 PM Joel Sherrill <joel at rtems.org> wrote:
>> On Thu, Jul 11, 2019 at 2:12 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>>> Hello,
>>> After Joel pointed out in an offlist discussion,
>>> I made a new patch for ndbm port.
>>> To send the changes to Newlib, i had to place `ndbm.h` , `ndbm.c` in their respective places and make  changes in Makefile.am.
>>> Before, I applied same patch to RSB hence ndbm library was not generated.
>> In my local build yesterday, I saw the symbols in the installed libc.a. I have not run the tests.
>>> This time I also added files generated by `autoreconf -fvi` in the patch.
>>> This patch is 10MB in size hence cannot be send in raw format on mailing list.
>> The person committing is supposed to do the autoreconf and commit that.
>> No one has answered if it is OK to commit. That was the last message in the thread.
> I will ping on that thread again for confirmation.
>>> This patch worked with RSB and ndbm library (lib_a-ndbm.o) was generated
>>> successfully in RTEMS Toolchain.
>> I'm hoping we can avoid this by pushing the patch to newlib, then bumping the hash for
>> newlib in the RSB, then adding your ndbm test patch to RTEMS.
> Yeah, meanwhile testsuite can be verified.
> Also, please look at the sources I send on devel for fenv. Should I ignore architectures
> which are not having FreeBSD source? or Should i pick from NetBSD and FreeBSD
> both?
Pick from both, figuring out how to translate the NetBSD
implementation to work with how the FreeBSD ones are implemented, if
necessary. Mostly, they define very similar data structures,
macros/functions, etc., so I think it should be possible to unify
them.
Gedare
>> --joel
>>> Thank you
>>> Vaibhav Gupta
