Sources for fenv (ARM, PPC, x86, SPARC and RISC5)
Joel Sherrill
joel at rtems.org
Tue Jul 16 12:56:42 UTC 2019
Let's give preference to FreeBSD sources. Notes below.
On Wed, Jul 3, 2019 at 1:08 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> Hello,
> I have found sources for fenv.
> 1.1) - ARM FreeBSD Source:
> - https://github.com/freebsd/freebsd/blob/master/lib/msun/arm/fenv.h
> - https://github.com/freebsd/freebsd/blob/master/lib/msun/arm/fenv.c
> 1.2) - ARM NetBSD Source :
> - https://github.com/NetBSD/src/blob/trunk/sys/arch/arm/include/fenv.h
> - https://github.com/NetBSD/src/blob/trunk/lib/libm/arch/arm/fenv.c
For the ARM FreeBSD source, there are some ifdef's which appear to
be for architectural variations. Please check the gcc source for arm
(gcc-XXX/gcc/config/arm) to see if they are defined by gcc. If they
all are, then there is nothing to consider on how they get tripped.
For example, __ARM_PCS_AAPCS64 is one. That looks like a multilib
define.
> 2.1) - SPARC NetBSD Source :
> - https://github.com/NetBSD/src/blob/trunk/sys/arch/sparc/include/fenv.h
> - https://github.com/NetBSD/src/blob/trunk/lib/libm/arch/sparc/fenv.c
This looks good and may work for sparc64 as well as sparc. Check if
sparc64-rtems5-gcc defines __arch64 as used byL
https://github.com/NetBSD/src/blob/trunk/sys/arch/sparc/include/fenv.h#L36
> 3.1) - PPC FreeBSD Source:
> - https://github.com/freebsd/freebsd/blob/master/lib/msun/powerpc/fenv.h
> - https://github.com/freebsd/freebsd/blob/master/lib/msun/powerpc/fenv.c
> 3.2) - PPC NetBSD Source:
> - https://github.com/NetBSD/src/blob/trunk/sys/arch/powerpc/include/fenv.h
> - https://github.com/NetBSD/src/blob/trunk/lib/libm/arch/powerpc/fenv.c
Sam advice on PPC. Looks OK, check ifdefs
> 4.1) - x86 FreeBSD Source:
> - https://github.com/freebsd/freebsd/blob/master/lib/msun/x86/fenv.h
> 4.2) - x86 NetBSD Source:
> - https://github.com/NetBSD/src/blob/trunk/lib/libm/arch/x86_64/fenv.c
This is not i386 (e.g. 32-bit), it is for the 64-bit target. Good to merge
it into
newlib but we don't have a fully functional port to test this with.
> 5.1) - RISC5 FreeBSD Source:
> - https://github.com/freebsd/freebsd/blob/master/lib/msun/riscv/fenv.h
> - https://github.com/freebsd/freebsd/blob/master/lib/msun/riscv/fenv.c
> 5.2) - RISC5 NetBSD Source:
> - https://github.com/NetBSD/src/blob/trunk/sys/arch/riscv/include/fenv.h
> - https://github.com/NetBSD/src/blob/trunk/lib/libm/arch/riscv/fenv.c
Same advice.
> It's impossible to depend on either NetBSD or FreeBSD.
Yep. Give preference to FreeBSD but if it isn't in FreeBSD, use NetBSD.
> For some architectures, FreeBSD has code,
> for some, NetBSD has.
> For x86, Free BSD has explicit header
> and NetBSD has .c file.
These are all architecture specific files so do not go in a main include
or source directory. They go in an architecture specific subdirectory.
See
https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=tree;f=newlib/libm/machine;h=9b2197b2660fd84c6b64ef265c1ec3b6e30c9074;hb=HEAD
And notice that arm, aarch64, riscv, and i386 are all already there. Looks
like you can focus on the ones not there (PPC and SPARC). Ignore x86_64
for now. If there is a ticket for the port, just add a comment to that. I
don't
think we are setup to test that port right now.
Hope that all makes sense.
--joel
> Vaibhav Gupta
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190716/9fc6f80a/attachment.html>
