GSoC Linux UIO driver for PRU
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Tue Jul 16 13:35:31 UTC 2019
On Tue, Jul 16, 2019 at 6:57 PM Nils Hölscher <nilhoel1 at gmail.com> wrote:
> Thanks I have been able to resolve this.
> But I have run into another issue.
> RTEMS port of the character device switch table doesn't support a .d_mmap
> entry.
> https://github.com/RTEMS/rtems-libbsd/blob/610349693dd31d8b0efd33776516b7187cc5cda2/freebsd/sys/sys/conf.h#L199
> And I am not certain how the struct rtems_filesystem_file_handlers_r and
> the structs cdevsw are related.
> The current BSD driver uses two  cdevsw structs, one to manage interrupts
> and one to manage io.
> Should or can I switch them out?
> Hi Nils,
I have recently worked on a patch to add d_mmap to libbsd. I couldn't send
it to devel because
it could not be tested.
Christian, by the time the VT issue is resolved. I would like to prepare a
separate clean patch
for the mmap, what is your suggestion about this?
Best,
> Nils
> On Tue, 16 Jul 2019 at 13:47, Joel Sherrill <joel at rtems.org> wrote:
>> On Tue, Jul 16, 2019, 6:34 AM Nils Hölscher <nilhoel1 at gmail.com> wrote:
>>> Hi,
>>> I am currently porting the pruss driver functions, that I want to add in:
>>> rtems_filesystem_file_handlers_r pruss_irq_handler.
>>> But when I add  my functions like this:
>>>   .open_h = ti_pruss_irq_open
>>> I receive the following compiler warnings:
>>> ../../pruss.c:156:13: warning: initialization from incompatible pointer
>>> type [-Wincompatible-pointer-types]
>>>    .open_h = ti_pruss_irq_open,
>>> ../../pruss.c:156:13: note: (near initialization for
>>> 'pruss_irq_handler.open_h')
>>> ../../pruss.c:158:13: warning: initialization from incompatible pointer
>>>    .read_h = ti_pruss_irq_read,
>>> Can anyone help please?
>> This usually means that either the prototype of the method has not been
>> seen before it is used or the method signature does not match that expected
>> of the indirect method pointer on the left hand side. Make sure the
>> signature matches.
>>> The full source can be found here:
>>> https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/pruss.c#L91
>>> https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/pruss.c#L155
>>> Best,
>>> Nils
>>> On Mon, 15 Jul 2019 at 10:15, Sebastian Huber <
>>> sebastian.huber at embedded-brains.de> wrote:
>>>> On 15/07/2019 10:10, Nils Hölscher wrote:
>>>> > Thanks this is very helpful.
>>>> > But has anyone an existing example of a similar driver?
>>>> > I wasn't able find one in /bsps, maybe I didn't search long enough.
>>>> There are some in cpukit:
>>>> cpukit/libcsupport/src/consolesimple.c:  IMFS_make_generic_node(
>>>> cpukit/libcsupport/src/termios.c:  rv = IMFS_make_generic_node(
>>>> cpukit/libcsupport/src/consolesimpletask.c:  IMFS_make_generic_node(
>>>> cpukit/include/rtems/imfs.h: *   rv = IMFS_make_generic_node(
>>>> cpukit/include/rtems/imfs.h:extern int IMFS_make_generic_node(
>>>> cpukit/libfs/src/imfs/imfs_make_generic_node.c:int
>>>> cpukit/dev/i2c/i2c-bus.c:  rv = IMFS_make_generic_node(
>>>> cpukit/dev/i2c/i2c-dev.c:  rv = IMFS_make_generic_node(
>>>> cpukit/dev/spi/spi-bus.c:  rv = IMFS_make_generic_node(
>>>> cpukit/libblock/src/blkdev-imfs.c:      int rv = IMFS_make_generic_node(
>>>> cpukit/libblock/src/blkdev-imfs.c:            rv =
>>>> Sebastian Huber, embedded brains GmbH
>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>> Phone   : +49 89 189 47 41-16
>>>> Fax     : +49 89 189 47 41-09
>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>> PGP     : Public key available on request.
>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190716/9874080c/attachment-0001.html>
