build of libbsd for powerpc fails with error: redefinition of 'eieio'
Wed Jul 17 05:48:22 UTC 2019
Hello Peter,
On 16/07/2019 19:58, Peter Dufault wrote:
> I have a build failure with the MVME5500 “beatnik” BSP. Therefore I tried to build the “psim” BSP and have the same failure: the FreeBSD PowerPC “cpufunc.h” and the RTEMS PowerPC “io.h” headers both define static inline "eioeio()" functions.
> - RTEMS, libbsd, RSB and the build tools are up-to-date as of this AM.
> - Building for arm xilinx_zynq_a9_qemu succeeds.
> - I’ll work-around it but I believe I must have something locally screwed up, I can't find any recent changes associated with this.
libbsd doesn't work for all BSPs. For each new BSP you there are
probably some things to fix and adjust. I think the <bsp.h> should not
include the low level io.h header file. The only powerpc BSP that
supported by libbsd is the qoriq.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
