[PATCH v4] Add mmap
Thu Jul 18 05:09:52 UTC 2019
On 17/07/2019 22:28, Vijay Kumar Banerjee wrote:
> +static int
> +testmmap(struct cdev *dev, vm_ooffset_t offset, vm_paddr_t *paddr,
> +         int nprot, vm_memattr_t *memattr)
> +	test_state *state = dev->si_drv1;
> +	assert(memattr == VM_MEMATTR_DEFAULT);
> +	assert(paddr != NULL);
> +	assert(nprot != PROT_NONE);
If you know the value in your test, then test for this value. You should
avoid != tests whenever possible.
Here the nprot should be PROT_READ | PROT_WRITE?
Does the MAP_SHARED not end up here somehow?
> +	assert(*state == TEST_KQFILTER);
> +	*state = TEST_MMAP;
> +	return 0;
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
