GSoC Linux UIO driver for PRU
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Jul 18 08:48:48 UTC 2019
On 18/07/2019 10:30, Nils Hölscher wrote:
> Hi,
> Do I need to add an rtems_filesystem_file_handlers_r struct to the pru
> driver to register it or are the cdevsw sufficient?
> Current status of the driver:
> https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/pruss.c#L806
> I am still not clear what the differences between these two structs are.
> Best,
> Nils
Hello Nils,
maybe there is a misunderstanding here: Vijays driver adds mmap support
to the libbsd devfs. So if you port a driver from FreeBSD via libbsd,
you can use the mmap of that driver (at least if the mmap returns a
pointer without any address translation or similar unsupported stuff).
The driver you just linked creates a RTEMS file system structure
directly. This structure could be used to create a file with
IMFS_make_generic_node directly.
Is there some reason that you try to create your own node instead of
using the already defined ti_pruss_cdevsw structure? With the make_def
in line 630 it should already create a file.
By the way: You create the structure in a
    #ifndef __rtems__
but it's a RTEMS type so it maybe should be a
    #ifdef __rtems__
instead.
Best regards
Christian
> On Wed, 17 Jul 2019 at 11:43, Nils Hölscher <nilhoel1 at gmail.com
> <mailto:nilhoel1 at gmail.com>> wrote:
>     Hi,
>     I applied the patch and now all compiles.
>     But I haven't tested anything yet, I am currently working on an
>     application for testing.
>     I will keep in contact concerning the mmap patch.
>     Best,
>     Nils
>     On Tue, 16 Jul 2019 at 15:47, Christian Mauderer
>     <christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>> wrote:
>         On 16/07/2019 15:35, Vijay Kumar Banerjee wrote:
>         > On Tue, Jul 16, 2019 at 6:57 PM Nils Hölscher
>         <nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>
>         > <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>> wrote:
>         >     Thanks I have been able to resolve this.
>         >     But I have run into another issue.
>         >     RTEMS port of the character device switch table doesn't
>         support
>         >     a .d_mmap entry.
>          https://github.com/RTEMS/rtems-libbsd/blob/610349693dd31d8b0efd33776516b7187cc5cda2/freebsd/sys/sys/conf.h#L199
>         >     And I am not certain how the
>         >     struct rtems_filesystem_file_handlers_r and the
>         structs cdevsw are
>         >     related.
>         >     The current BSD driver uses two  cdevsw structs, one to manage
>         >     interrupts and one to manage io.
>         >     Should or can I switch them out?
>         > Hi Nils,
>         > I have recently worked on a patch to add d_mmap to libbsd. I
>         couldn't
>         > send it to devel because
>         > it could not be tested.
>         > Christian, by the time the VT issue is resolved. I would like
>         to prepare
>         > a separate clean patch
>         > for the mmap, what is your suggestion about this?
>         You create a clean patch only for mmap. Please don't forget to add a
>         test case to the libbsd devfs test. Although I would have
>         preferred a
>         working driver to test it, it should be OK to be added without
>         one if
>         the devfs test works.
>         Please send a preview of the patch (without devfs test) to the
>         mailing
>         list so that Nils can already have a look at it and try it.
>         Best regards
>         Christian
>         >     Best,
>         >     Nils
>         >     On Tue, 16 Jul 2019 at 13:47, Joel Sherrill
>         <joel at rtems.org <mailto:joel at rtems.org>
>         >     <mailto:joel at rtems.org <mailto:joel at rtems.org>>> wrote:
>         >         On Tue, Jul 16, 2019, 6:34 AM Nils Hölscher
>         >             Hi,
>         >             I am currently porting the pruss driver functions,
>         that I
>         >             want to add in:
>         >             rtems_filesystem_file_handlers_r pruss_irq_handler.
>         >             But when I add  my functions like this:
>         >               .open_h =ti_pruss_irq_open
>         >             I receive the following compiler warnings:
>         >             ../../pruss.c:156:13: warning: initialization from
>         >             incompatible pointer type
>         [-Wincompatible-pointer-types]
>         >                .open_h = ti_pruss_irq_open,
>         >             ../../pruss.c:156:13: note: (near initialization for
>         >             'pruss_irq_handler.open_h')
>         >             ../../pruss.c:158:13: warning: initialization from
>         >                .read_h = ti_pruss_irq_read,
>         >             Can anyone help please?
>         >         This usually means that either the prototype of the
>         method has
>         >         not been seen before it is used or the method
>         signature does not
>         >         match that expected of the indirect method pointer on
>         the left
>         >         hand side. Make sure the signature matches.
>         >             The full source can be found here:
>          https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/pruss.c#L91
>          https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/pruss.c#L155
>         >             Best,
>         >             Nils
>         >             On Mon, 15 Jul 2019 at 10:15, Sebastian Huber
>         >             <sebastian.huber at embedded-brains.de
>         <mailto:sebastian.huber at embedded-brains.de>
>         <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>         >                 On 15/07/2019 10:10, Nils Hölscher wrote:
>         >                 > Thanks this is very helpful.
>         >                 > But has anyone an existing example of a
>         similar driver?
>         >                 > I wasn't able find one in /bsps, maybe I
>         didn't search
>         >                 long enough.
>         >                 There are some in cpukit:
>         >                 cpukit/libcsupport/src/consolesimple.c:
>         >                 IMFS_make_generic_node(
>         >                 cpukit/libcsupport/src/termios.c:  rv =
>         >                 cpukit/libcsupport/src/consolesimpletask.c:
>         >                 cpukit/include/rtems/imfs.h: *   rv =
>         >                 cpukit/include/rtems/imfs.h:extern int
>         >                 cpukit/libfs/src/imfs/imfs_make_generic_node.c:int
>         >                 cpukit/dev/i2c/i2c-bus.c:  rv =
>         >                 cpukit/dev/i2c/i2c-dev.c:  rv =
>         >                 cpukit/dev/spi/spi-bus.c:  rv =
>         >                 cpukit/libblock/src/blkdev-imfs.c:      int rv =
>         >                 cpukit/libblock/src/blkdev-imfs.c:            rv =
>         >                 Sebastian Huber, embedded brains GmbH
>         >                 Address : Dornierstr. 4, D-82178 Puchheim, Germany
>         >                 Phone   : +49 89 189 47 41-16
>         >                 Fax     : +49 89 189 47 41-09
>         >                 E-Mail  : sebastian.huber at embedded-brains.de
>         >                 PGP     : Public key available on request.
>         >                 Diese Nachricht ist keine geschäftliche
>         Mitteilung im
>         >                 Sinne des EHUG.
>         >             _______________________________________________
>         >             devel mailing list
>         >             devel at rtems.org <mailto:devel at rtems.org>
>         <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>         >             http://lists.rtems.org/mailman/listinfo/devel
>         >     devel mailing list
>         > devel mailing list
>         Herr Christian Mauderer
>         Dornierstr. 4
>         D-82178 Puchheim
>         Germany
>         email: christian.mauderer at embedded-brains.de
>         Phone: +49-89-18 94 741 - 18
>         Fax:   +49-89-18 94 741 - 08
>         PGP: Public key available on request.
>         Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
>         EHUG.
> devel mailing list
> devel at rtems.org
Dornierstr. 4
D-82178 Puchheim
Germany
