GSoC Linux UIO driver for PRU
Thu Jul 18 08:57:00 UTC 2019
On 18/7/19 6:48 pm, Sebastian Huber wrote:
> On 18/07/2019 10:41, Nils Hölscher wrote:
>> So I will be fine just using the BSD structs?
> I don't know what you want to do. If you already have FreeBSD kernel code, then
> using the FreeBSD API is probably easier.
Does this determine where we place the PRU code?
If any dependent part is in LibBSD then we should have all the support in
LibBSD. I do not see any point having a part in the BSP code and then needing
LibBSD.
And I also think LibBBSD will always be used on a BBB. It is too boring without it.
