GSoC Linux UIO driver for PRU
Nils Hölscher
nilhoel1 at gmail.com
Thu Jul 18 09:11:31 UTC 2019
Thanks everyone,
@Sebastian Huber <sebastian.huber at embedded-brains.de> I was just confused
because of the examples I got earlier using rtems IMFS but now everything
is clear.
The BSD Documentation helps thanks again.
@Christian Mauderer <christian.mauderer at embedded-brains.de> Thanks for
pointing out the relevant parts I wasn't seeing at the moment.
The defines were intended since I am not using these parts, I will delete
them now that I won't use them.
@chrisj at rtems.org <chrisj at rtems.org> but where do we place the shell part,
which exists between BSD and RTEMS?
However this doesn't have priority right now, does it?
Best,
Nils
On Thu, 18 Jul 2019 at 10:57, Chris Johns <chrisj at rtems.org> wrote:
> On 18/7/19 6:48 pm, Sebastian Huber wrote:
> > On 18/07/2019 10:41, Nils Hölscher wrote:
> >> So I will be fine just using the BSD structs?
> > I don't know what you want to do. If you already have FreeBSD kernel
> code, then
> > using the FreeBSD API is probably easier.
> Does this determine where we place the PRU code?
> If any dependent part is in LibBSD then we should have all the support in
> LibBSD. I do not see any point having a part in the BSP code and then
> needing
> LibBSD.
> And I also think LibBBSD will always be used on a BBB. It is too boring
> without it.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190718/452eb670/attachment.html>
