GSoC PRU: simplebus vs nexus
Thu Jul 18 11:34:59 UTC 2019
On 18/07/2019 12:58, Nils Hölscher wrote:
> Hi,
> What is the state of simplebus in rtems-libbsd?
It works fine.
> I found the simplebus files in the rtems-libbsd repository, but when
> building the compiler is not able to resolve the following include:
> #include<dev/fdt/simplebus.h>
Not all header files are installed with a "./waf install". You can add
libbsd based drivers to "rtemsbsd/sys/dev".
> Should I go with nexus instead as described in this Blog from 2015 or is
> it outdated?
> https://ragustechblog.blogspot.com/2015/06/porting-driver-from-freebsd-to-rtems.html
Yes, device tree based BSPs should use the simplebus.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
